December 15, 2011, 02:20 |
Verification of this phase change modeling
kawamura
Rep Power: 14 |
Hi everyone.
I'm trying to two phase flow with phase change using VOF method. There are some approach for mass transfer modeling. I'm interested in the following way. mDot = K/L * grad(T)・grad(F) Note that K refers to the mixture thermal conductivity, F refers to the volume fraction and L is the latent heat. But I couldn't find that verification. If you understand this correctry, please let me know the verification! Thanks a lot. |
December 20, 2011, 02:54 |
Masashi Ohbuchi
Rep Power: 16 |
Hi, Kawamura-san,
I can not make a verification for this notation. But I think grad(F) should be grad(F)/mag(grad(F)). This means unit normal vector of interface. |
December 20, 2011, 04:46 |
kawamura
Rep Power: 14 |
Hi Ohbuchi-san,
thanks for your response. but FLUENT and some people show this expression in their paper . there is non-existence of normal vector. I think the most accurate expression is... mDot = 1/L *(qg-ql)・n *Aint/V (kg/m^3 /s) in evaporating where qg and ql is heat flux in gas and liquid phase respectively,Aint is interface area,V is volume of cell and n is unit normal vector. but getting the correct interface area is so difficult in VOF. so I think that grad(F) may works as n・Aint/V . but i don't get a correct understanding about this |
December 21, 2011, 00:59 |
Masashi Ohbuchi
Rep Power: 16 |
Hi. Kawamura-san,
The value of grad(F) will be very large on sharp interface, so I think some limiter function will be needed to restrict the value within 0-1. And, I think it's impossible to determine interface area from grad(F) without assuming specific flow regime(such as stratified flow or bubbly flow). BTW, the expression of mas transfer by heat transfer; mDot = (k/L) grad(T) grad(F)/mag(grad(F)), was originally introduced in following paper. Son,G. and Dhir,V.K. A level set method for analysis of film boiling on an immersed solid surface. Nummer. Heat Transfer B,vol.52,pp.153-177.(2007) This expression is only valid on stratified flow regime. |
December 21, 2011, 01:14 |
kawamura
Rep Power: 14 |
Hi Ohbuchi-san,
It's useful information for me! Now it's starting to make sense. I consider about assuming specific flow. Thank you for your kindness. Kawamura |
phase change, vof |
Display Modes | |
UDF of "anisotropic phase function" in radiation modeling | whiz | Fluent UDF and Scheme Programming | 0 | September 1, 2009 04:26 |
thermal phase change question | CFDflying | CFX | 1 | February 18, 2004 05:10 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
phase change | rookie | FLUENT | 3 | June 12, 2003 21:47 |
Phase change modelling | Sebastien DANIEL | FLUENT | 1 | July 6, 2000 04:35 |
