faceSet utility
Old   April 29, 2011, 04:20
Default faceSet utility
Juanito
Aerospace is on a distinguished road
Hi everybody
I want to share my problem in order to somebody can help me.
I want to select some faces of my mesh in order to set a cyclic type patch. I use the following makeZones file:
faceSet fan new boxToFace (x y z) (x y z)
and then I run the following command:
setSet -batch makeZones
The result of this instruction is shown in attached file.
You can see that there are two different colors, and when I run the case, the cyclic patch has different effects as if it had different sign.
Of course, I would like this don't happen.
Any suggestion?
Thanks
Aerospace is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
