Rotor stator interaction LES simulation
Old   May 4, 2011, 07:05
Default Rotor stator interaction LES simulation
Thomas Lloyd
Thomas_Lloyd is on a distinguished road
Hi all,
I want to conduct a LES simulation of a ducted propeller using sliding mesh. I am running OF 1.7.1.
Can I do this using dynamicMeshDict & mixerFvMesh? What is the appropriate solver? pimpleDyMFoam?
I have read that this kind of simulation may not be possible under this development of OpenFOAM. Is this correct?
Also, regarding mixerFvMesh, is the setup limited to having the rotor inside the stator (like a pump)? Can it be applied to a case where the stator is upstream or downstream of the rotor i.e. sliding perpendicular to the axis of rotation?
Any help on this would be much appreciated.
Thanks,
Thomas
Thomas_Lloyd is offline   Reply With Quote
dynamic meshing, les, sliding mesh
continue LES simulation after it stopped holand_us OpenFOAM 9 April 5, 2010 12:52
How to determinate turbulence scale in LES (laminar simulation)? Franciswu21 ANSYS 0 October 22, 2009 12:48
LES simulation of bluff body at Re(d)=1200 arash_nl FLUENT 0 June 1, 2009 13:16
LES simulation! fpz FLUENT 0 March 27, 2005 21:32
LES simulation of sonic jet Jianping Main CFD Forum 0 January 21, 2005 05:52
