Building tutrial on SL6 (OF1.7.1)
Old   May 25, 2011, 22:51
Default Building tutrial on SL6 (OF1.7.1)
waku2005 is on a distinguished road
Dear all,
Does anyone can build some solvers on Scientific Linux 6 ?
Of cource I know that SL6 is not tested for OF platfoam.
In my case, I've downloaded from centFOAM site and successfully run icoFoam of OF 1.7.1.
As a next step, go to the simpleWindFoam case and run 'wmake' in the solver folder.
Messages below were shown and failed to build.
Any comments are welcome and thanks in advance
waku2005
[waku@ensisSL simpleWindFoam]$
[waku@ensisSL simpleWindFoam]$ wmake
SOURCE=simpleWindFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels -I/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/incompressible/RAS/RASModel -I/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/transportModels -I/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/transportModels/incompressible/singlePhaseTransportModel -I/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -I/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/simpleWindFoam.o
In file included from /home/waku/OpenFOAM/ThirdParty-1.7.1/platforms/linux64/gcc-4.4.4/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/bits/localefwd.h:42,
from /home/waku/OpenFOAM/ThirdParty-1.7.1/platforms/linux64/gcc-4.4.4/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/string:45,
from /home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/string.H:51,
from /home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/word.H:43,
from /home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/int.H:39,
from /home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/label.H:58,
from /home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/labelList.H:35,
from /home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/Pstream.H:43,
from /home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/OPstream.H:35,
from /home/waku/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/parRun.H:35,
from /home/waku/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude/fvCFD.H:4,
from simpleWindFoam.C:33:
/home/waku/OpenFOAM/ThirdParty-1.7.1/platforms/linux64/gcc-4.4.4/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h:52: error: 'uselocale' was not declared in this scope
/home/waku/OpenFOAM/ThirdParty-1.7.1/platforms/linux64/gcc-4.4.4/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h:52: error: invalid type in declaration before ';' token
/home/waku/OpenFOAM/ThirdParty-1.7.1/platforms/linux64/gcc-4.4.4/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h: In function 'int std::__convert_from_v(__locale_struct* const&, char*, int, const char*, ...)':
/home/waku/OpenFOAM/ThirdParty-1.7.1/platforms/linux64/gcc-4.4.4/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h:72: error: '__gnu_cxx::__uselocale' cannot be used as a function
/home/waku/OpenFOAM/ThirdParty-1.7.1/platforms/linux64/gcc-4.4.4/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h:97: error: '__gnu_cxx::__uselocale' cannot be used as a function
/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude/readSIMPLEControls.H: In function 'int main(int, char**)':
/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude/readSIMPLEControls.H:6: warning: unused variable 'momentumPredictor'
/home/waku/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude/readSIMPLEControls.H:9: warning: unused variable 'transonic'
make: *** [Make/linux64GccDPOpt/simpleWindFoam.o] Error 1
waku2005 is offline   Reply With Quote
Old   May 26, 2011, 02:00
Matthias Walter
matthias is on a distinguished road
I have got same error using CentOS5.5 some times ago. That's not a problem of SL6, it's a problem related to your gcc. It seems that the gcc included in Thirdparties was built using another version of c++locale.h from an older linux system.
Try to use the native gcc provided by your SL6 installation. That should do the job.
Good luck
Matthias
matthias is offline   Reply With Quote
Old   May 26, 2011, 02:04
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
As Matthias states the centFOAM version of 1.7 was built on 5.x system which has an older glibc.
Similar discussion can be found here
http://comments.gmane.org/gmane.comp.gcc.help/35639
You need to compile OF yourself (using system gcc) until I get 1.7/1.6-ext built for 6.x systems and uploaded to the centFOAM page.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   May 26, 2011, 03:42
Dear Linnemann
Thank you very much for your information.
I'll try to use system compiler and rebuild it.
waku2005
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 00:48
ParaView 3.8.0 problem on debian Unseen OpenFOAM Installation 4 August 16, 2010 10:26
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
