pyFoam, pyFlu, extend: How does they relate?
Old   May 12, 2011, 07:08
Default pyFoam, pyFlu, extend: How does they relate?
Florian
Horus is on a distinguished road
I've just began working with pyFoam (which seems pretty well designed so far...). But I'm a bit confused about the projekt structure:
There is http://sourceforge.net/projects/pyfoam/ which says that the project has moved to pyFlu... the homepage of pyFlu though makes not mention of that (beside one sentence). The current released package contains no sign of pyFoam and on the projekt page I found no reference to a VCS (subersion, git, ...).
http://openfoamwiki.net/index.php/Contrib_PyFoam however links to http://sourceforge.net/projects/openfoam-extend/ which contains an SVN with the source code of pyfoam.
My questions are:
- Are pyFoam and pyFlu are going to merge?
- What is the current source code repository for pyFoam?
- How do these projects relate...?
Thanks!
Horus is offline   Reply With Quote
Old   May 12, 2011, 09:19
Elvis
elvis will become famous soon enough
PyFoam (swak4foam http://openfoamwiki.net/index.php/Contrib/swak4Foam and many other tools like groovyBC and funkySetFields ) are based on the work made by Bernhard Gschaider.
pyFlu is the successor of "valushaka (with another pyfoam)" and is based on the work of Alexey Petrov and his collegues read http://pythonflu.wikidot.com/ or http://www.cfd-online.com/Forums/ope...vulashaka.html
Bernhard Gschaider made some comments in that thread as well
elvis is offline   Reply With Quote
Old   May 12, 2011, 09:56
Florian
Ok, thanks for the (non) clarification. ;-)
The openFoam community seems to be pretty scattered and suffering some not-invented-here syndrome.
I think I'll stick the pyFoam project mentioned here http://openfoamwiki.net/index.php/Contrib_PyFoam.
Old   May 17, 2011, 15:08
Florian
Just another follow up...
Any one knows whats the source repository in which development happs of pyfoam is? If I understand the wiki doc correctly it's not https://openfoam-extend.svn.sourcefo...ipting/PyFoam/
(e.g. for contributing back fixes)
Old   May 18, 2011, 03:32
Assistant Moderator
Bernhard Gschaider
Currently development happens in a private SVN. From time to time I mirror that to the SVN above and call it a release.
Changes done to the Sourceforge-SVN will be transplanted to my development version
Bernhard
Old   May 18, 2011, 05:04
alexey2petrov's Avatar
Alexey
alexey2petrov is on a distinguished road
Hi Horus,
The openFoam community seems to be suffering some not-invented-here syndrome
Here is some explanation on this point :
Originally Posted by alexey2petrov View Post
pyFoam and pythonFlu suggest completely different approaches (one controls OpenFOAM solver execution from outside, another aims to define OpenFOAM solver from inside) and do not overlap their goals with each other
Actually, this was an accidental name collision, not "me-not-invented-yet" syndrome. To resolve this issue VulaSHAKA's pyFoam project was recently renamed to pythonFlu. So, if you are interested into enhancing your CFD calculation environment with some kind of automation and interactivity, OpenFOAM community will be happy to supply you with two different approaches, at least - what ever you prefer .
Best regards,
Alexey
alexey2petrov is offline   Reply With Quote
Old   May 19, 2011, 05:01
Florian
Ah, ok. The name collision confused me.
Bernhard: If I had any patched for pyFoam should I send a diff to yours? Have you ever thought about switching to a more open development model?
Old   May 19, 2011, 09:44
Assistant Moderator
Bernhard Gschaider
Yep. If that becomes a habit I'd prefer to set you up access to the SVN because that way contributions can be attributed to whoever did them
Old   May 19, 2011, 11:37
Florian
Let's see what comes...
I dare to post my first question here. I try to use CaseBuilder to prepare a case. My understanding is:
- CaseBuilder take the files listed in parameterfiles from the template dir and copies them over. (+ modifications)
- If <meshpreparation mode="utility"> is given it runs the specified utility on the new case.
- It creates the boundary condition based on <boundaries> and <bc>.
I have an Case.template directory which just contains 0/.., constant/.., system/... No polyMesh anywhere.
pyFoamCaseBuilder.py case.pfcb case.test DrivFliess110209.msh
gives (case.test does not exist):
Problem reading the boundary file: [Errno 2] No such file or directory: '[...]/sandbox/case.test/constant/polyMesh/boundary.gz'
which is perfectly correct. But why is fluentMeshToFoam no being run before, which should create the polyMesh.
My case.pfcb: http://pastebin.com/aKUiu9zh
Thanks!
Old   May 21, 2011, 12:49
Florian
Somehow I'm to stupid to figure out how to send a private message to you...
I've made a bugfix to CaseReport.py. What's the best way to contribute it back to you?
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 09:23
Extend Project Release 1.6-ext hjasak OpenFOAM Announcements from Other Sources 33 July 14, 2011 18:54
[PyFoam] batch set up for OF 1.7 eelcovv OpenFOAM Community Contributions 3 January 19, 2011 08:38
[PyFoam] setting is not correct? or not compatible with 1.6? seasoul OpenFOAM Community Contributions 2 March 23, 2010 11:42
How can I extend the domain in Fluent? gabrielg FLUENT 1 November 12, 2008 00:44
