simpleFunctionObjects (surface)
Old   June 4, 2011, 10:07
Default simpleFunctionObjects (surface)
Nima Samkhaniani
nimasam is on a distinguished road
how to prepare controlDic to use set or surface in simpleFunctionObjects?
the main question is that i like to have sample surfaces along a tube, prependiculare the center line of cylindar, then i like to average the value of a field in these sample surfaces. is it possible with simpleFunctionObjects? how?
nimasam is offline   Reply With Quote
Old   June 7, 2011, 07:10
Assistant Moderator
Bernhard Gschaider
Not with simpleFunctionObjects, but with swak4Foam. For sampling this relies on OF-functionality (so you've got to find a way to sample on a cylinder)
sample surface, simplefunctionobjects
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
