September 21, 2011, 03:04 |
Gauss Quadrature points
supercommandodhruv
Rep Power: 14 |
Hi All,
I am calculating volume flow in a channel, and want to use the Gauss quadrature to calculate the volume flow rate. I searched on the net, and found some tables that have the points ( abscissa) and the corresponding weighting functions. As far as i understood, I can select any of the points in my domain as a point corresponding to one of the Gauss point (say of 5X5 matrix points), and then can use co-ordinate transformation to select the other points. What happens however, if the other points are outside the domain? How can I select the points then? Is there some rule to fix the points according to my domain? Thanks, Dhruv |
gauss quadrature, weighting functions |
Problem in fvschemes divSchemes cannot use Gauss linearUpwind | nico765 | OpenFOAM Bugs | 30 | August 9, 2018 07:39 |
please help me which solver is better for my application | Ger_US | OpenFOAM | 8 | January 8, 2013 12:29 |
Submarine with SimpleFoam | alex_rubel | OpenFOAM | 20 | February 25, 2011 06:34 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 01:23 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
