Is it suitable to use Weller's scheme in this case? |
June 17, 2011, 16:16 |
Hi Foamers,
In order to strictly restrict alpha in [0,0.52], I am now considering to use MULES in case of bubbly flow. I have a question here since in Weller's scheme, there is a compression term (eqn 4.13, Rusche). And it is said "The artificial term is only active in the thin interface region because of the multiplication term gamma(1-gamma)". It is true in case of liquid-vapor with clear interface which only exists somewhere. However in bubbly flow, the interface could be everywhere. I dont know if it is appropriate to use this scheme in my case. Thanks. // Kai |
June 21, 2011, 16:56 |
#2 | |
Santiago Marquez Damian
Rep Power: 23 |
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
June 21, 2011, 18:03 |
I do not track bubbles interface. As you said, the bubbles interface is treated as a dispersed interface.
Kai |
June 21, 2011, 18:08 |
Rep Power: 23 |
Hi, MULES and interfaceCompression are intended for VOF problems in which surface is completely described and tracked. Maybe you can explain your case a little bit in order to see if it is possible to use these techniques in your case.
Regards.
June 22, 2011, 05:43 |
It is a two-phase Euler-Euler case. And I think the the way you define the compression term is different between the interface-tracking and dispersed interface (eqn 3.58 and eqn 4.13, Rusche). In my case, there are two velocity fields: Ua and Ub, instead of the single velocity field in the interface-tracking case.
Kai |
June 22, 2011, 08:09 |
#6 | |
Patricio Bohorquez
Just run simple benchmarks to compare with analytic solutions and see what happens. I feel you will be happy with your results.
bc's of a komegaSST case | Zymon | OpenFOAM | 11 | July 25, 2010 09:36 |
Need help to open an OpenFoam case with Paraviw | aaurouss | OpenFOAM | 2 | July 6, 2009 13:18 |
Time discretisation scheme for steady state case | Andrey | CFX | 7 | September 16, 2008 03:40 |
extrapolation in MUSCL scheme | Chandra | Main CFD Forum | 6 | February 14, 2007 11:21 |
Roe Scheme; Shock Boundary layer Interaction | Mohammad Kermani | Main CFD Forum | 5 | December 20, 1999 15:44 |
