Placing second fluid in OpenFOAM.
Old   June 30, 2011, 06:15
Default Placing second fluid in OpenFOAM.
Vivek Gupta
vivek070176 is on a distinguished road
Hye,
Considering dam break case, i changed the location of water column and placed it as shown below. I want to place another fluid at the bottom of it, what changes do i need to do?
Thanks
Vivek
vivek070176 is offline   Reply With Quote
Old   June 30, 2011, 06:22
Vivek Gupta
Please see the attachment for the position of fluid.
Old   June 30, 2011, 06:37
Arne Stahlmann
Arnoldinho is on a distinguished road
The dam break case is a tutorial for the interFoam solver, which works for two fluids (e.g. water and air). If you want another, third fluid, you will need a different multiphase solver.
Arnoldinho is offline   Reply With Quote
Old   June 30, 2011, 06:39
Vivek Gupta
Thank you for the reply.
But, instead of air i want to place another fluid which has density little less than water at the bottom of it. How to do that?
I am talking of two fluids water and say oil.
Vivek
Old   June 30, 2011, 09:29
Nima Samkhaniani
nimasam is on a distinguished road
you can have just two fluids and no vacuum! if you want to change properties look at transportproperties at constant folder!
nimasam is offline   Reply With Quote
Old   June 30, 2011, 18:33
Wouter van der Meer
wouter is on a distinguished road
Vivek
look in tutorials/multiphase/multiphaseInterFoam/laminar/damBreak4phase
there is an example how to set up OpenFoam for four phases
I have not tried to make it three, maybe this is possible as well.
Best
Wouter
wouter is offline   Reply With Quote
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Summer School on Numerical Modelling and OpenFOAM hjasak OpenFOAM 5 October 12, 2008 13:14
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
