rhoCentralFoam Solver
Old   July 6, 2011, 01:21
Default rhoCentralFoam Solver
venkat
venkataramana is on a distinguished road
hi all,
here i am using a new scheme with rhoCentralFoam Solver, it is compiling without problems, while running the code there are errors given below,
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Reading field U
Reading thermophysicalProperties
fluxScheme: newScheme
Starting time loop
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
in "/root/OpenFOAM/root-1.7.1/applications/bin/linuxGccDPOpt/newSolver"
#6 __libc_start_main in "/lib/libc.so.6"
Segmentation fault
Regards
Venkat
venkataramana is offline   Reply With Quote
Old   July 6, 2011, 03:25
Rickard
Rickard.Solsjo is on a distinguished road
Printstack is usually divide by zero.
Did you try changing some of the conditions in your 0-directory?
Otherwise, it might just be some mesh problem, try to run blockMesh again or something like this.
Rickard.Solsjo is offline   Reply With Quote
Old   July 6, 2011, 05:07
Default hi Rickard,
venkat
thanks for your reply,
no errors with blockMesh,
Old   July 20, 2011, 09:58
Default Problem to generate the mesh
R. P.
Rophys is on a distinguished road
hello everybody,
I'm using the rhoCentral Foam (2.0 version) and I have been problems to generate my mesh. My mesh is composed by two regions, the first one is rectangular and the second one is a parallelepiped. For the region when I run the commands blockMesh and checkMesh everything is ok, but when I introduce the second region the openFoam give the following error: "number of edges not aligned or perpendicular to non-empty directions". I substituted the parallelepiped region for other rectangular region and everything works fine. Maybe the openFoam don't accept angles in the mesh ? Somebody could help me ? Thanks
Rophys is offline   Reply With Quote
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 19 February 27, 2024 09:44
[Other] A New Solver for Supersonic Combustion nakul OpenFOAM Community Contributions 20 February 22, 2019 09:08
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Development of a Low mach PISO solver nishant_hull OpenFOAM Programming & Development 0 August 25, 2009 12:48
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
