Relative flux in pimpleDyMFoam
Old   July 20, 2011, 17:50
Default Relative flux in pimpleDyMFoam
Igor_2011 is on a distinguished road
Hi Foamers!
I've recently been trying to simulate the plunge motion of a 2D cylinder using pimpleDyMFoam and the rigid body deformation technique, or solidBodyMotionFvMesh. Although the simulations converge, I noticed that the entire flow solution moved with the cylinder, which is not very physical!
I started to think about this issue and the first thing that came out to my mind was that there may have an issue with the part of the code that should make the flow relative to the mesh motion. However, when I looked at the files (see the code below) everything looked correct to me since at the beginning of each iteration the fluxes are made absolute, then the mesh position is updated before make the flux relative again.
Any one has a clue regarding this issue?
Great thanks!
    // Make the fluxes absolute
        fvc::makeAbsolute(phi, U);
        #include "setDeltaT.H"
        runTime++;
        Info<< "Time = " << runTime.timeName() << nl << endl;
        mesh.update();
        if (mesh.changing() && correctPhi)
            #include "correctPhi.H"
        // Make the fluxes relative to the mesh motion
        fvc::makeRelative(phi, U);
        if (mesh.changing() && checkMeshCourantNo)
            #include "meshCourantNo.H"
        // --- PIMPLE loop
        for (int ocorr=0; ocorr<nOuterCorr; ocorr++)
            if (nOuterCorr != 1)
                p.storePrevIter();
            #include "UEqn.H"
            // --- PISO loop
            for (int corr=0; corr<nCorr; corr++)
                rAU = 1.0/UEqn.A();
                U = rAU*UEqn.H();
                phi = (fvc::interpolate(U) & mesh.Sf());
                if (p.needReference())
                    adjustPhi(phi, U, p);
                for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
                    fvScalarMatrix pEqn
                        fvm::laplacian(rAU, p) == fvc::div(phi)
                    pEqn.setReference(pRefCell, pRefValue);
                    if
                        ocorr == nOuterCorr-1
                     && corr == nCorr-1
                     && nonOrth == nNonOrthCorr)
                        pEqn.solve(mesh.solver(p.name() + "Final"));
                    else
                        pEqn.solve(mesh.solver(p.name()));
                    if (nonOrth == nNonOrthCorr)
                        phi -= pEqn.flux();
                #include "continuityErrs.H"
                // Explicitly relax pressure for momentum corrector
                if (ocorr != nOuterCorr-1)
                    p.relax();
                U -= rAU*fvc::grad(p);
                U.correctBoundaryConditions();
            turbulence->correct();
Igor_2011 is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
What is the problem with the relative Flux Correction danielle OpenFOAM Running, Solving & CFD 0 November 1, 2008 23:24
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
