Install troubles on fedora
Old   July 19, 2011, 23:28
Default Install troubles on fedora
yoshimitsuspeed is on a distinguished road
I am having problems getting openfoam to run. Installed from source pack and finally up to this point.
Create a project directory within the $HOME/OpenFOAM directory named <USER>-2.0.0 (e.g. chris-2.0.0 for user chris and OpenFOAM version 2.0.0) and create a directory named run within it, e.g. by typing:
mkdir -p $FOAM_RUN
Copy the tutorial examples directory in the OpenFOAM distribution to the run directory. If the OpenFOAM environment variables are set correctly, then the following command will be correct: cp -r $FOAM_TUTORIALS $FOAM_RUN
Run the first example case of incompressible laminar flow in a cavity: cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
blockMesh
icoFoam
paraFoam
From there I have exactly the same troubles as this guy. Found his thread searching for the problem.
http://forums.linuxmint.com/viewtopic.php?f=90&t=36177
* Getting Started
<USER>-1.6 (e.g. 'chris-1.6' for user chris and OpenFOAM version 1.6)
and create a directory named 'run' within it, e.g. by typing:
+ mkdir -p $FOAM_RUN/run
Copy the 'tutorial' examples directory in the OpenFOAM distribution to the
'run' directory. If the OpenFOAM environment variables are set correctly,
+ cp -r $WM_PROJECT_DIR/tutorials $FOAM_RUN
Right of this i have managed to create a file named tom-1.6.x
when I type the mkdir into the terminal nothing actually happens so far as i can see. (Is it supposed to???)
So i assumed i had that right seen as nothing erroneous came up and typed in the cp command.
This did throw up the error:
cp: missing destination file operand after '/tutorials'
Only difference is I am running 2.0
yoshimitsuspeed is offline   Reply With Quote
Old   July 20, 2011, 02:49
Joel Lehikoinen
joel.lehikoinen is on a distinguished road
I'd say your environmental variables are not set up. You can run echo $FOAM_RUN and if it prints nothing, then those variables are not set. Did you remember to do this:
if running bash or ksh (if in doubt type echo $SHELL), source the etc/bashrc file by adding the following line to the end of your $HOME/.bashrc file:
source $HOME/OpenFOAM/OpenFOAM-2.0.0/etc/bashrc
then type “source $HOME/.bashrc” in the current terminal window
Especially the last line. Adding the line to your .bashrc file means that it will be run every time you start a new terminal, but if you haven't started a new terminal yet, then it has not been run, and environmental variables have not been set. And do make sure you are running the correct shell!
joel.lehikoinen is offline   Reply With Quote
Fedora 15 install help jenkins OpenFOAM Installation 10 October 27, 2011 17:51
install openfoam in fedora Ahmed Khattab OpenFOAM Installation 32 September 23, 2011 11:11
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 11:18
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
Ubuntu AMD64 Installation Troubles mkw87 OpenFOAM Installation 31 April 27, 2008 13:59
