OpenFoam 2.0 hopper case visualization with Paraview
Like Tree3Likes
  • 2 Post By pius
  • 1 Post By amscosta
Old   July 28, 2011, 11:06
Default OpenFoam 2.0 hopper case visualization with Paraview
Alexandre M S Costa
amscosta is on a distinguished road
Dear All,
How can I visualize the data generated from the lagrangian/hopper case simulation
with paraview 3.10 ?
Any clue is very welcome.
Thanks.
Alex
P.S. Could anybody share the procedure for viewing the discrete element modelling
hopper picture showed in the openfoam.com site ?
amscosta is offline   Reply With Quote
Old   August 29, 2011, 03:07
Hyung Min Kim
pius is on a distinguished road
you can make the animation file of the tutorial example of hopper by uisng the paraview.
After getting the simulation results by running the program.
Generating the VTK files using foamToVTK command.
Open the VTK file uisng paraview as following procedure
Run paraview
open the files at the directory of " icoUncoupledKinematicParcelFoam -> hopper -> hopperEmptying -> VTK -> lagrangian-kinematicCloud "
At the paraview, insert the filter Glyph with the sphere type, scalar mode and 0.1 of radius.
and save the animation at the "file" manu
good luck
pius
czhao86 and wbywbywby6 like this.
pius is offline   Reply With Quote
Old   August 29, 2011, 03:14
Hyung Min Kim
I will post the animation file soon
Old   August 30, 2011, 14:37
Astrid Mahrla
AMahrla is on a distinguished road
You could have a look at the OpenFOAM-wiki entry "Tutorials for particle based methods". Chapter 2 is about PostProcessing..
Best,
Astrid
AMahrla is offline   Reply With Quote
Old   September 1, 2011, 08:31
Question
Alexandre M S Costa
Thanks for the reply and the links.
I just followed the foamtoVTK and all I get is a pile
of spheres "frozen", no matter how I pressed the play
button.
SimonStar likes this.
Old   September 1, 2011, 10:28
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Try deleting the 0 file in the converted VTK (especially in the lagarangian folder), then start paraview again.
Pei
phsieh2005 is offline   Reply With Quote
Old   September 8, 2011, 09:17
Alexandre M S Costa
No success deleting the 0 file.
Any other clue ?
Old   September 8, 2011, 10:56
Claudio Wolfer
wWieWalter is on a distinguished road
Hi amscosta
I do the following tasks after the solver has finished:
1) rm -r 0
2) paraFoam
3) in ParaView press apply
4) in mesh parts select kinematicCloud - lagrangian
5) in lagrangian fields U andothers > apply
6) menu filters > alphabetical > extractBlock
7) select lagrangian (black cross) > apply
8) glyph > glyph type sphere > radius 0.? > theta resolution 24 > scale mode off > apply
9) choose display color
Now you shoud see your particles. I play with the Radius as long as it seems to fit the real radius. I don't know how to apply the geometrical radius in ParaView.
I hope this instruction helps you.
wWW
wWieWalter is offline   Reply With Quote
Old   September 14, 2011, 10:04
Alexandre M S Costa
Hi Claudio,
Those are the available itens in the Mesh Parts :
frontAndBack - patch
inlet - patch
internaMesh
outlet - patch
walls - patch
Unfortunatelly there is no "kinematicCloud - lagrangian" available
The lagrangian Fiels is also empty
Anyone with clues please jump in.
Alex
Old   September 14, 2011, 10:13
Claudio Wolfer
Hi
Are you shure you deleted directory 0 (zero) before typing paraFoam?
wWW
Old   September 14, 2011, 17:33
Question
  #11
Alexandre M S Costa
Yes, i just typed rm -r 0 under the case directory.
Old   September 15, 2011, 02:44
Claudio Wolfer
Good morning,
I guess that in the hopper-directory you typed ./Allrun. After run has finished you changed to > hopperEmptying and deleted 0-directory. When you open an other time directory you should see a > lagrangian and a > uniform directory and some files called > kinematicClaudUCoeff, kinematicCloudUTrans, mu, phi, rho, U. Within the > lagrangian and uniform directories you should see again a > lagrangian directory (with some content).
If you do not see that stuff your computations failed. In my installation of OF2.0.1 this tutorial runs very well. So if it does not work for you, try to rerun the case after reinstalling the tutorial.
ParaView runs good with other cases?
hopper, lagrangian visualization
Building a custom solver on OpenFOAM 2.0 wschosta OpenFOAM Programming & Development 1 July 8, 2011 15:07
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
[OpenFOAM] Visualization with ParaView (in general) sega ParaView 7 February 1, 2010 02:24
Velocity vector data in OpenFOAM and ParaView mismatch tekky OpenFOAM 9 December 21, 2009 11:26
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
