adjointShapeOptimizationFoam pointers
Old   August 4, 2011, 16:15
Default adjointShapeOptimizationFoam pointers
Nick Gardiner
NickG is on a distinguished road
Hi
Could someone give me some pointers for the values of alphaMax and lambda in the transportProperties for the adjointShapeOptimizationFoam solver in OF2.0.
Are they related to the inlet velocity? Unfortunately I don't have access to the aiaa paper referred to in another thread so can't read that. I can see the equation in the .c source file but don't understand it fully.
I've tried varying the values for the pitzDaily example and get similar results within a certain range but am not sure which are more valid/accurate. Should I try to find the midpoint of the range or does the better result lie closer to the unbalanced result...
Answers on a post... please
Nick
NickG is offline   Reply With Quote
Old   August 5, 2011, 17:19
Nick Gardiner
Okay so alpha essentially relates to a porosity coefficient.Is lambda the second coefficient of viscosity, the eigenvalue of one of the matrices or something else?
Old   October 20, 2011, 14:23
David Boger
boger is on a distinguished road
Hi Nick,
As I also mentioned here, lambda refers to the step size taken in the steepest descent optimization, which helps (along with the under-relaxation factor that is applied) to control how rapidly alpha changes.
As far as the values, I suspect lambda is based on trial-and-error, and probably alphaMax is too. The porosity (alpha) just needs to grow to be "large enough" to slow the velocity in those cells to near-zero by way of the drag term in the momentum equation, and at some point, it probably becomes a question of diminishing returns in terms of convergence to let alpha grow indefinitely.
Hope that helps,
David
David A. Boger
boger is offline   Reply With Quote
Old   October 21, 2011, 06:34
Nick Gardiner
Thanks David. I've been playing around with it and getting seemingly sensible results but it's nice to know why!
Nick
Old   November 16, 2011, 06:21
FlowLy
giuli@ is on a distinguished road
Hi all..
my question is: does the geometry actually changes or the plots of alpha just give an indication of where to optimize the shape?
Both in the tutorial and in another case made by me no shape is optimized o.O
could you please give some directions..?
cheers
giuli@ is offline   Reply With Quote
Old   November 16, 2011, 07:32
David Boger
The interface between alpha=1 and alpha=0 indicates the location where the optimal boundary should be, but the geometry/mesh is not changed directly. Go back to the reference listed in the source code for adjointShapeOptimizationFoam.C.
David A. Boger
Pasing Pointers to functions solve and linearInterpolate arkangel OpenFOAM Programming & Development 0 July 7, 2011 09:05
Multiple inheritance, function pointers or? ngj OpenFOAM 0 March 20, 2009 10:36
pointers and threads Andrew Garrard FLUENT 3 March 16, 2004 12:57
Pointers to wall adjacent cells in CFX 5 Fabian CFX 2 November 21, 2002 11:14
Pointers --- (CFX4-3) Alex CFX 0 April 15, 2002 15:03
