How to set transient velocity inlet bc
Old   September 3, 2011, 10:39
Default How to set transient velocity inlet bc
LijieNPIC is on a distinguished road
Hi, foamers
Now I have a problem and need your help. I want to simulate spatial developing pipe flow and heat transfer by DNS. So first I performed fully developed pipe flow with DNS. And now I want to set the inlet velocity bc with transient outlet velocity of the fully pipe flow. I don't know how to do it.
I searched the forum and found some related thread:
timeVaryFlowRateInletVelocity bc and set time varying flowrate, but the velocity distribution cannot be changed.
groovBC utility can set velocity distribution, but the distribution should be a function
So I need your help. Thanks in advance!
LijieNPIC is offline   Reply With Quote
Old   September 4, 2011, 11:43
Nima Samkhaniani
nimasam is on a distinguished road
as a suggestion you can use two blocks and make the first block long enough to reach the fully developed solution then using cyclic boundary condition between to block patches and then in ur second block ur inlet is fully developed!!!!
but if ur inlet and out let have the same mesh, you can easily do it manually!!! just you need to change the patches name in ur dictionary!!! or copy the nonuniform value at outlet into ur inlet in time zero!!!
nimasam is offline   Reply With Quote
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
Transient Velocity Inlet for an airfoil ! Titasse FLUENT 3 May 12, 2010 11:06
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
udf inlet velocity is not set correctly, why ? GaoGe FLUENT 0 June 17, 2008 08:33
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 10:15
