how to improve time step
Old   September 3, 2011, 13:41
Default how to improve time step
send1000 is on a distinguished road
I am trying to use SIMPLE algorithm to simulate a 2D flow in micro rectangle pipe. I set up the constant pressure values as inlet and outlet boundary condition and two side is no slip wall. The large scale differences between pressure and size of the pipe leads to the results that it converges only if the step time is very very small(10e-9s). Who could tell me how to do if I want to improve step time to 1s~0.001s?
send1000 is offline   Reply With Quote
Old   September 6, 2011, 22:11
Alberto Passalacqua
If you use simpleFoam to deal with an unsteady problem, this is not correct. You should use pisoFoam or pimpleFoam.
If you use pimpleFoam, you can use larger time steps using under-relaxation and outer correctors (under-relaxation is not appropriate in pisoFoam).
Alberto Passalacqua
Old   September 7, 2011, 16:00
Thank you very much , alberto
Do you know where I can find the details about Pimple method? I am programming now by myself and I need make sure every details.
Thank you again.
Old   September 7, 2011, 21:06
Alberto Passalacqua
I am not aware of references about it. You can take a look at pimpleFoam to see how it is implemented.
Alberto Passalacqua
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
Intermediate step during a time step Burn OpenFOAM 0 July 16, 2009 10:01
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
