extrudeMesh - odd behaviour
Old   September 20, 2011, 08:41
Default extrudeMesh - odd behaviour
grjmell is on a distinguished road
I have a mesh in with snappy in which I refine around a pipe cross-section and a stl surface a the bottom. I then convert that into a 2D snappyHexMesh, so I run extrudeMesh. This step works well sometimes, but sometimes, i get odd behaviour at the bottom where it just creates an outlier point. this point is not there after snappyHexMesh runs. extrudeMesh creates this for some reason i can't explain. As i said, sometimes it works ok then with a slightly changed bottom stl it won't and the odd points might occur in a different place (see images). The bottom stl is created using the constantIso sampling tool in sampleDict if that makes any difference. Has anyone experienced this before? what could be the issue? the hex-meshing step always works ok, the extrusion seems to be an issue.
grjmell is offline   Reply With Quote
extrudemesh
Odd behaviour in wigleyHull in OF 2.0 msbealo OpenFOAM Running, Solving & CFD 0 July 16, 2011 05:53
Unstable behaviour after long period of stablility plunge11 FLUENT 1 April 6, 2011 09:15
Fluent strange behaviour (occasional divergence) muketa FLUENT 0 March 18, 2010 04:55
BIG Problem in extrudeMesh! wind_fyp OpenFOAM 0 January 28, 2010 00:40
Modelling Industrial cyclone behaviour Günther Hasse Main CFD Forum 3 October 12, 1999 19:34
