the problem about dimension
Old   October 15, 2011, 03:58
Default the problem about dimension
bojiezhang
bojiezhang is on a distinguished road
hello everyFoamer:
I have two problems, and hope someone can help me,
1:when I use the function below:
Foam::cos( -omega*runTime.value())
the dimension of omega is[0,0,-1,0,0,0,0],
It can compile pretty well, but when caculating, the error comes as below:
ds not dimensionless
From function cos(const dimensionedScalar& ds)
2:when I assign the value as below:
mass[cellI] =A*omega*Foam::cos(-omega*runTime.value());
mass is volScalarField , and intialized as dimensionedScalar("zero", dimensionSet(0,1,-1,0,0,0,0), 0.0)
the dimension of A is [0,1,0,0,0,0,0],the dimension of omega is[0,0,-1,0,0,0,0],
when compiled , it shows "error":can not convert dimensioned<double> to double ;
what can I do , I really hope someone can give me some advice, thank you in advance!
bojiezhang
bojiezhang is offline   Reply With Quote
Old   October 15, 2011, 09:00
Nima Samkhaniani
nimasam is on a distinguished road
1) define omega as dimless , because when u use the value() function, it only returns the value of run time not its dimension!
2) its not important whats the dimension of volScalarField is, when you use just on array of it! its a scalar with out dimension so the left side should be dimensionless too, but ur left side is not dimension less, its an strange combination of [0 0 1 0 0 0 0]* cos [0 0 -1 0 0 0 0] for compiler, so define A as dimless too then
congratulation both ur problem get solved
nimasam is offline   Reply With Quote
Old   October 16, 2011, 00:22
bojiezhang
Thank you for your reply, the problem is solved successfully by your idea!
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
