collapseEdges (after makeAxialMesh) not worked
Like Tree2Likes
  • 2 Post By markusrehm
Old   June 23, 2011, 17:12
Default collapseEdges (after makeAxialMesh) not worked
mechy is on a distinguished road
I have used makeAxialMesh to run flow in pipe at first I create 2D mesh and then Run
makeAxialMesh -axis lower -wedge frontAndBack -overwrite
mesh is created successfully but when I run
collapseEdges 1e-4 179.5 -overwrite
I encountered bellow error
Create time
Create polyMesh for time = 0
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam:olyMesh::calcDirections() const in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam:olyMesh:olyMesh(Foam::IOobject const&) in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/bin/collapseEdges"
#6 __libc_start_main in "/lib/libc.so.6"
Floating point exception
please help me
mechy is offline   Reply With Quote
Old   September 21, 2011, 10:10
Markus Rehm
markusrehm is on a distinguished road
Hello
try
"unset FOAM_SIGFPE"
Markus
liquidspoon and Taltan like this.
markusrehm is offline   Reply With Quote
Old   November 17, 2011, 15:09
Default Thanks
Alex
liquidspoon is on a distinguished road
Thanks for the unset command trick, that seemed to work
liquidspoon is offline   Reply With Quote
[mesh manipulation] makeAxialMesh and axisymmetric flow yassepid OpenFOAM Meshing & Mesh Conversion 5 January 28, 2024 22:38
[Other] makeAxialMesh issue feijooos OpenFOAM Meshing & Mesh Conversion 8 October 23, 2014 05:21
makeAxialMesh > collapseEdges!! billynoe OpenFOAM 17 February 21, 2011 04:29
[mesh manipulation] CollapseEdges after makeAxialMesh utility in subversion testcase bonzodeb OpenFOAM Meshing & Mesh Conversion 1 June 5, 2009 03:24
Modification of collapseEdges utility olwi OpenFOAM Bugs 0 September 9, 2008 08:35
