Foam error
Old   November 25, 2011, 03:53
Default Foam error
A.D.E is on a distinguished road
Dear all,
I am running a Subsonic case using sonicFoam in 4 processors and I get this error message:
--> FOAM FATAL ERROR:
[0] Maximum number of iterations exceeded
[0]
[0] From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const
[0] in file /home/opencfd/OpenFOAM/OpenFOAM-2.0.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67.
[0]
FOAM parallel run aborting
[0]
[0] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1 Foam::error::abort() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::eConstThermo<Foam:: perfectGas> > > > >::calculate() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
[0] #3 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::eConstThermo<Foam:: perfectGas> > > > >::correct() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
[0] #4
[0] in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/sonicFoam"
[0] #5 __libc_start_main in "/lib/libc.so.6"
[0] #6
Does anyone know the reason why p { margin-bottom: 0.21cm;and how can I fix it ?
Thank you,
Ade
A.D.E is offline   Reply With Quote
Old   November 28, 2011, 15:02
Adhiraj
adhiraj is on a distinguished road
The question is not clear to me. Do you want to know why the code crashed, or is it something about the p field?
OpenFOAM solves the energy equation for Enthalpy (h/hs) or internal energy(e). Then it needs to invert a relation like
e=e(T)
or
h=h(T)
or
hs=hs(T)
This is done by a Newton iteration method. If the method does not converge after a reasonable number of iterations, you get the error you mentioned.
As to why you are getting this error, it can be a lot of things, so I can't tell right away why the number of iterations is exceeded.
Hope that helps.
adhiraj is offline   Reply With Quote
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
user defined function cfduser CFX 0 April 29, 2006 10:58
