Reletive Motion
Like Tree1Likes
  • 1 Post By deepsterblue
Old   April 26, 2011, 06:57
Default Reletive Motion
Dan
dandalf is on a distinguished road
Hi all,
I am working on simulating the flow over a moving three dimensional body immersed in incompressible fluid.
In openFoam 1.7.0, I am using pimpleDyMFoam to achieve the local deformation of the body however I now need to simulate the net movement of the body. To minimize the mesh transformation cost and to keep my object of interest centered in my mesh, I wish to take a Eulerian approach, and simply update the relative free stream velocity at each iteration.
For this I need to update not just the relative boundary velocity values but also the velocities of the internal mesh.
Can anybody suggest a way to achieve this. Am I missing an obvious trick here?
dandalf is offline   Reply With Quote
Old   April 26, 2011, 15:17
Pablo
pablodecastillo is on a distinguished road
Hi Dan,
I think that you can do it with solidbodymotion, it has SDA and SDK class, who let define movements for the domain. But they are very restrictives. So it seems that if you want to implement your own movements with ODE or similar, you can move your domain with fvMesh::movePoints.
fvMesh::movePoints will move your points and calculate volumen variation, phi variation etc... then this value will be used by makerelative or makeabsolute to take account the influence of the velocity body/domain in your problem.
In theory it will be done, if it is wrong i hope that somebody give light.
Do not forget say mesh.moving(true);, or makerelative and absolute is not going to work.
Pablo
pablodecastillo is offline   Reply With Quote
Old   April 26, 2011, 16:11
Sandeep Menon
deepsterblue will become famous soon enough
fvMesh::movePoints() calls polyMesh::movePoints(), which in-turn calls the moving(bool) member function, so there's no need to call the moving() function explicitly
pablodecastillo likes this.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   April 26, 2011, 17:38
Pablo
And when/where is updated C() and Cf()?, i was trying to find it without succesful.
Pablo
Old   April 26, 2011, 19:55
Sandeep Menon
All geometry is demand-driven. Once movePoints is called, geometry information is cleared (using clearGeom()? Can't remember the function name), and reconstructed on-demand only when mesh.C(), etc is called the next time.
Look for calls to deleteDemandDrivenData() in the source-tree for clues...
Sandeep Menon
Old   April 26, 2011, 22:24
Pablo
So, i can not find what i am missing.
I am coding a solver based in interdymfoam, but using my own movement mesh.
The problem is that when i move all the domain, the free surface is moving with the domain, it is like flux relative was not working right for phi interface.
Any idea?
Pablo
Old   April 27, 2011, 12:29
Pablo
I go to try to explain my problem better;
The solver is solving the towing tank resistance for ships with trim and sink. It is using rigid body motion (motion for all the domain) to trim&sink.
The mistake is coming when solving the sink, when the boat (all the domain) goes up or down, the free surface is going with him (so if the body sink 10 cm all the domain is moving too 10 cm and the free surface level too). It means that the relative flux is not updating the free surface or i am not giving the properly boundary conditions.
Any idea??
Advanced thanks
Old   April 27, 2011, 19:19
Pablo
Hello again,
I found that i have no relative flux, i did it surfaceScalarField phi44 = fvc::meshPhi(U); and i got 0 for the average of phi44. It seems that phiPtr_ is not saving the old value. Anybody can help me to figurate what is happening?
Pablo
Old   December 6, 2011, 12:08
Arne Stahlmann
Arnoldinho is on a distinguished road
Hi Pablo,
I think I am facing a similar problem right now (but am still figuring out if it might be related to your situation): After modifying the point positions, the water in my flume is running out of it. Boundary conditions for U and alpha1 are still properly defined.
So: Did you figure out what the reason was, and could you fix it?
Greetings,
Arne
Arnoldinho is offline   Reply With Quote
Old   December 20, 2011, 07:08
Pablo
Hi Arne,
Sorry this late reply. I fixed doing fix the velocity at the top and bottom of the domain, in my case it works pretty well.
Pablo
Mesh motion on inlet (2-way FSI) Lance CFX 2 August 13, 2009 05:31
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
tank motion on boat Tim FLUENT 0 May 23, 2007 11:50
large scale mesh motion sb FLUENT 1 April 27, 2007 22:23
Can I define grids motion as a time functions Darcy CFX 4 March 29, 2001 21:14
