[Gmsh] Meshing thin, curved solids in Gmsh
Old   January 5, 2012, 11:05
Question Meshing thin, curved solids in Gmsh
Tibi Chelcea
tibich72 is on a distinguished road
I've encountered a problem for a design I'm trying to mesh with Gmsh. Basically, the issue is in a solid that looks like a hollow cone; the wall cone is very thin (the thickness of the wall is 0.1, while the top diameter of the cone is 10, and the bottom is 6; height is 14). The issue seems to be with the 2D meshing of the outer and inner cone surfaces: some of the triangles from the outer surface intersect some triangles on the inner surface.
This design is supposed to be simulated a lot of times with slight variations, so I'd like to get a small mesh that's amenable to quick simulations. In my experiments so far a mesh of about 100K elements with a meshing time of 45s is good.
I can change Mesh.MinimumCirclePoints in the .geo file, but if I set it high enough to avoid the issue, meshing takes 4 minutes and results in 800k mesh elements. I can also change the characteristic length (either for the entire design or just a box around this solid), but the result is again a large mesh and very slow meshing.
Is there a way to avoid the issue of intersecting triangles while avoid a big penalty in speed/size?
Thanks.
Tibi
tibich72 is offline   Reply With Quote
gmsh, thickness, thin walls
[Gmsh] GMSH error when meshing "airfoil_validation" githib's example uzzi OpenFOAM Meshing & Mesh Conversion 2 October 11, 2018 16:05
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
thin extrusion meshing guillaume Main CFD Forum 0 October 27, 2008 18:36
Xperimental data on thin curved plates/airfoils turb Main CFD Forum 0 September 15, 2005 15:15
Meshing thin surfaces Louwrens CFX 8 August 18, 2003 17:49
