Courant number
Old   February 14, 2012, 21:54
Default Courant number
Melika
libra is on a distinguished road
Hi everyone
I am simulating the water flow in a pipe using LES with OpenFoam version 1.6.
It seems that there is something wrong with "courant number" in my computations. During the computations it gets bigger and bigger and finally the computation stops. The value I should choose for courant number is 5*10^-4 according to the calculations, but I have even chosen a smaller value: 10^-5. I am wondering why this number gets so big?????
libra is offline   Reply With Quote
Old   February 15, 2012, 04:35
niaz's Avatar
A_R
niaz is on a distinguished road
Dear libra
it is big problem in openfoam. but it has easy solution
you can limit your courant with "maxCo 0.2;"
it controls your courant and adapt your time steps.
niaz is offline   Reply With Quote
Old   February 15, 2012, 22:56
Melika
Hi Niaz
Thanks for your comment. I limited the Courant number and my computation is running for now. I hope it works.
Old   February 17, 2012, 04:48
Melika
Originally Posted by niaz View Post
Dear libra
Dear Niaz
I changed my "controlDict" file to the following to limit the courant number:
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application channelFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 1;
deltaT 1e-5;
writeControl adjustableRunTime;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.5;
maxDeltaT 1;
functions
fieldAverage1
type fieldAverage;
functionObjectLibs ( "libfieldFunctionObjects.so" );
enabled true;
outputControl outputTime;
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
But it didn't work and the courant number exceeds 0.5. Do you have any idea about this?
Thanks
Old   February 22, 2012, 14:02
niaz's Avatar
A_R
Libra
channelFoam cannot control courant number.
you should add setDeltaT.H to your solver.
Old   February 22, 2012, 14:03
niaz's Avatar
A_R
If you need help just look at pimpleFoam as an example.
Old   February 23, 2012, 21:25
Melika
Thanks Niaz. Problem solved.
Old   April 9, 2014, 07:06
Duarte Magalhães
DuarteMagalhaes is on a distinguished road
Hi everyone. I'm using icoFoam and i want to control the Courant number. I've tried to insert "maxCo 0.5;" in the controlDict file, but it didn't work. Can anyone help me on this?
DuarteMagalhaes is offline   Reply With Quote
Old   April 9, 2014, 07:40
Bernhard
Bernhard is on a distinguished road
The solution is in this topic. Read carefully!
Bernhard is offline   Reply With Quote
Courant number fireman FLUENT 7 September 11, 2021 11:33
IcoFoam unstability, courant number gets large! vivien OpenFOAM 11 March 9, 2017 03:45
LES near wall model & courant number kasim CFX 5 March 16, 2008 18:23
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Courant number calculation - unsteady flow Kuba FLUENT 0 November 8, 2005 22:44
