which tools do you chosse to get mesh of Askervein? |
March 5, 2012, 09:01 |
张德胜
Rep Power: 14 |
Hi ,everyone.I use snappyhexmesh to get mesh of Askervein hill .But the simulation can not convergent in any way.I think it is the mesh's fault.But i see that the tutorials in simpleFoam/turbinesiting is getting mesh through snappyhexmesh,and the case is ok.who can give me some advice about mesh of hill.Thanks a lot.
March 6, 2012, 22:01 |
张德胜
Rep Power: 14 |
Thank you ,nimasam for your reply.I use globalmapper to get a bigger terrain and applicate this terrain into my case. Lukily,it is ok.but i also get some error,they are:
1--> FOAM Warning : Displacement (-0.0105444431492 -0.000833083815678 0.6463200786) at mesh point 182214 coord (-984.348568667 -1124.719101 17.9943627872) points through the surrounding patch faces 2--> FOAM Warning : From function layerParameters::layerParameters(..) in file autoHexMesh/autoHexMeshDriver/layerParameters/layerParameters.C at line 379 Reading "/root/OpenFOAM/root-2.1.0/run/tutorials/incompressible/simpleFoam/wf24/system/s nappyHexMeshDict::addLayersControls::layers" from line 267 to line 272 Layer specification for sphere.stl_firstSolid does not match any patch. 3--> FOAM Warning : From function layerParameters::layerParameters(..) in file autoHexMesh/autoHexMeshDriver/layerParameters/layerParameters.C at line 379 Reading "/root/OpenFOAM/root-2.1.0/run/tutorials/incompressible/simpleFoam/wf24/system/s nappyHexMeshDict::addLayersControls::layers" from line 267 to line 272 Layer specification for maxY does not match any patch. 4--i choose the addlayer in the snappyhexmeshdict,but in the final ,it fail. This is my first time to use snappyhexmesh,so i have some thing which is not clear to me.i hope you can help me when you are free.Thanks a lot. |
July 31, 2013, 01:32 |
#4 | |
ehk
Rep Power: 13 |
hi hei@ge,
have you been able to run Askervein hill successfully. Would it be possible to send me the case directory you have used? Thanks Quote:
hill snappyhexmesh |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[snappyHexMesh] non-smooth mesh | Svensson | OpenFOAM Meshing & Mesh Conversion | 11 | January 18, 2012 09:13 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
