icoPoly8ThermoPhysics limits density below 2 kg/m3
Old   March 16, 2012, 04:28
Default icoPoly8ThermoPhysics limits density below 2 kg/m3
Sinisa Majer
smajer is on a distinguished road
Hello all,
I am trying to use chtMultiRegionSimpleFoam with liquid (water). Since it is important to take in account buoyant forces I have specified thermophysical properties as:
thermoType hRhoThermo<pureMixture<icoPoly8ThermoPhysics>>;
Unfortunately, it seems that a density is limited to 2 kg/m3.
To demonstrate this, I have changed the thermophysicalProperties file in multiRegionHeater case (tutorial for chtMultiRegionSimpleFoam).
For density (in this case constant, but it is just to demonstrate the problem) lower then 2 solver is using the value from thermophysicalProperties file. For density above 2 solver is fixing density to 2.
| \\ / O peration | Version: 2.1.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant/topAir";
object thermophysicalProperties;
mixture
specie
nMoles 1;
molWeight 28.9;
equationOfState
// rhoCoeffs<8> ( 1.999 0 0 0 0 0 0 0 ); //If you use this, density is constant but lower then 2
rhoCoeffs<8> ( 2.1 0 0 0 0 0 0 0 ); //If you use this, density is constant and always 2 (it is same even if you put other coefficients for polynom)
thermodynamics
Hf 0;
Sf 0;
CpCoeffs<8> ( 1000 0 0 0 0 0 0 0 );
transport
muCoeffs<8> ( 1.8e-05 0 0 0 0 0 0 0 );
kappaCoeffs<8> ( 0.0242 0 0 0 0 0 0 0 );
Pr 0.7;
Why is that so? In OF documentation (http://www.openfoam.com/features/thermophysical.php) we can find this statement:
"icoPolynomial - Incompressible polynomial equation of state, e.g. for liquids"
Can someone explain this?
Best regards,
Sinisa
smajer is offline   Reply With Quote
Old   March 16, 2012, 05:41
Aurelien Thinat
Aurelien Thinat is on a distinguished road
Check out your fvSolution file. You may have limited the density value range.
Aurelien Thinat is offline   Reply With Quote
Old   March 16, 2012, 06:11
Sinisa Majer
Well, that was quick and efficient!!
Thank you very much!!
That was the problem. I searched everything before posting here, but I didn't notice that density is limited in fvSolution.
Once again,
thanks!
Sinisa
chtmultiregionsimplefoam, constant rho, icopoly8thermophysics, liquid
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 14:20
Variable Density Function ryzd FLUENT 1 August 25, 2011 14:16
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
variable density water Atit Koonsrisuk CFX 2 July 24, 2003 03:07
