Problems with an unsteady problem
Old   March 30, 2012, 08:44
Default Problems with an unsteady problem
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am running buoyantPimpleFoam to study an unsteady case, of course. I want to simulate the transient of the temperature inside a room, when I am cooling it down.
I have a complex mesh (I got it from Fluent) and I have both a structured and an unstructured mesh.
The point is that it works only if I choose these solvers:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "rho.*"
        solver			GAMG;
	preconditioner		GAMG;
	mergeLevels		1;
	smoother		GaussSeidel;
	agglomerator		faceAreaPair;
	nCellsInCoarsestLevel	100;
	tolerance		1e-08;
	relTol			0.01;
    p_rgh
        solver			GAMG;
	mergeLevels		1;
	tolerance		1e-08;
	relTol			0.01;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "(U|h|k|epsilon|R)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-09;
        relTol          0.01;
	/*solver		smoothSolver;
        tolerance	1e-08;
        relTol		0.01;
    	nSweeps		1;*/
        /*solver			GAMG;
	mergeLevels		6;
	tolerance		1e-08;
	relTol			0.01;*/
    "(U|h|k|epsilon|R)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor yes;
    nOuterCorrectors 2;
    nCorrectors     3;
    nNonOrthogonalCorrectors 2;
On the contrary, if I try to use either GAMG or smoothSolver I have a very strange behaviour at the interface (I mean where there is the transition between the structured and the unstructured mesh): the velocity increase (as if there is a source).
Do you know why this happens?
You can und that it is a very problem, since the solution should not depend on the solver I choose.
Any idea?
Thanks,
Samuele
samiam1000 is offline   Reply With Quote
Old   April 5, 2012, 03:49
Sachin Kanetkar
sachin is on a distinguished road
Hi Samuele..
Did you check changing value for nNonOrthogonalCorrectors...
Perhaps the solvers would be sensitive to this value...Just a passing thought ...
Best Luck
Sachin
sachin is offline   Reply With Quote
Using sliding mesh for unsteady turbomachinery problem happyman Main CFD Forum 3 July 8, 2011 14:29
unsteady convergence problem for bluff body Byukuya FLUENT 2 October 28, 2010 10:59
unsteady flow problems Daniel FLUENT 0 January 25, 2009 23:54
SOS: About VOF-Dynamic mesh unsteady problem whpsoft FLUENT 4 May 9, 2006 19:26
Question concerning about unsteady problem.... ghlee Main CFD Forum 6 October 2, 1998 05:36
