[General] PARAVIEW from C code: system(...)
Old   February 24, 2007, 08:57
Default PARAVIEW from C code: system(...)
simone Marras
Hello, I need to tell my code written in C that I want to view the grid I compute by launching Paraview from within the code by using the comman "system(...)".
The question is:
What script do I need to use when I call paraview and want it to open directly in the file of interest (analogoue to what "paraFoam" does when I type paraFoam <input> <output>)?
ex. system("paraview ...???...") so that paraview opens and directly open the file I want to look at
I hope the question is clear since I realize it seems quite tricky for my english!
Thank you
simone marras
Old   February 26, 2007, 07:57
Default re: PARAVIEW from C code: system(...)
Renato.
Just type paraview --help to see the available options. I guess that you can do what you want by simply using
paraview --data=<your_data_file>
cheers
Renato.
Old   February 26, 2007, 08:36
simone Marras
Hello Renato, thank you for the hint. I actually type paraview --data (in my case file99.vtk for ex), or also paraview --help but in both cases it just opens paraview without opening any file or any help options in the terminal.
I use the X11 to open it on the Mac osX
Thanks a lot
simone
Old   February 26, 2007, 10:44
Renato.
It's not the best way for using PV if you've been using it remotely...
anyway, have you tried to write the full path of your data file with the --data option? Without the full path PV will try to look for the data file within the PV root directory (I guess).
Regards
Renato.
ps.: I tried here in a Windows machine and the --data option worked perfectly.
Old   February 26, 2007, 11:00
simone Marras
Hello Renato, this is what I actually put in X11:
> paraview /MYPATH/file.vtk
or even
> paraview --/MYPATH/file.vtk
but it still oopens PV without opening the file.vtk
Anyway, maybe it's because of my installation on my machine or it might be a Mac characteristc when running PV.
Thanks anyway. I let u know if I solve it in any other way
Regards,
Simone
Old   February 26, 2007, 11:48
Renato.
try it:
paraview --data=/MYPATH/file.vtk
Old   February 26, 2007, 12:30
simone Marras
Negative also this one. Im beginning to think it depends on the installation and architecture since you can get it to work on windows.
Thank you very much for trying to help;
are you italian for any chance?
Best regards,
simone
[General] Equivalent C++ code for applied filters in Paraview Sandbad ParaView 0 January 12, 2018 20:14
[General] Post-Process StarCCM+ in ParaView bias ParaView 0 December 15, 2017 04:38
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 12:30
code for solving block tridiagonal system cfd Main CFD Forum 22 December 24, 2010 17:15
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
