May 17, 2004, 23:44 |
how to set inlet and outlet?
Air is export from a pipe having special shape with a fun, the pipe is in a room. The volume rate of the fan is given. I want to konw the velocity and pressure in the pipe, how I should set the inlet and outlet? I have tried different ways. First, I set the velocity at outlet, but the pressure in the pipe is positive, but this is not right. Then I set the outlet to default, and before the outlet I set a fan with given volume rate, but it seems difficult to converge. Do you have any good idea? Thanks.
May 17, 2004, 23:53 |
Re: how to set inlet and outlet?
Green,
If you are trying to look at the properties in the pipe only, then I suggest setting up the problem as follows. Define the pipe, maybe using BFC. Define the fan as an inlet with a fixed m3/sec Define the outlet as an opening, with the correct coefficient. Check POLIS for this as it has some good examples. Hope this helps. Leon |
May 18, 2004, 00:54 |
I have done it in the way you told. But I also want to know if there is a smoke source at the inlet of the pipe, all the smoke will be export through the pipe or there will be some s,oke going into the room space. So I can't set an inlet at one end of the pipe, do you have any good idea? Thanks
May 18, 2004, 01:36 |
The big question is, does the pressure profile in the pipe matter.
If not, just model the smoke entering the room from the pipe. You could work out from a 'pipe only' model the flow accross the outlet and ake the intel into the room, seperate model, be the same. There maybe be a way of linking the two but I do not know how. Otherwise to get suffcient resolution in the pipe region look at fine grid embedding. |
May 18, 2004, 23:41 |
The pressure in the pipe is what I want to know. I only know the velocity at the fan and the pressure at the room which is 1.0e5. I want to know the pressure and velocity in the pipe. I have tried to do it in such a way. Just before the outlet, I set a fan with the given velocity, but I don't know how to set the pressure in the outlet, because I don't know the pressure drop in the pipe. In fact, the pressure drop is what I want to konw.
May 18, 2004, 23:52 |
Green,
If all you are after is the pressure drop in the pipe. Set up the geometry of the pipe. If there are bends or the like i recomend using BFC. I find that with fans it is better to set the inlet pressure, to induce a velocity, or a flow rate. I have found this method to be more reliable when I want to find out velocities and pressures. If you are talking about friction losses, have a look through POLIS and CHAM website, for examples on wall friction and surface roughness. I would set the oulet pressure to be the ambien tpressure of the room. For this type of example it would seem fair. Leon |
Without Inlet and outlet | chetan | FLUENT | 4 | February 11, 2008 12:45 |
Inlet-outlet BCs | SUBHRA | Main CFD Forum | 0 | June 3, 2004 20:15 |
one inlet and two outlet | Fluenter | FLUENT | 2 | March 28, 2004 23:23 |
use outlet as inlet | Karin | Phoenics | 3 | March 31, 2003 22:12 |
Outlet -> Inlet How? | lego | CFX | 2 | August 13, 2002 12:23 |
