How to set rotational flow in inlet ?
Old   September 13, 2004, 02:40
Default How to set rotational flow in inlet ?
wright
I bulid the model in cartesian,Gas get into the rectangular vessel through inlet .but the gas from inlet is rotational flow .How to set the swirl-nozzle type inlet .
Old   September 15, 2004, 13:03
Default Re: How to set rotational flow in inlet ?
Mick Hughes
Hi Assuming you are using the VRE, create a FAN object and this will have an option for swirl. Set up a simple test case with the fan as the inlet and experiment, hopefully the option dialogs should make sense.
Old   January 6, 2005, 01:45
hamed
please send text & images & animation of thise subject for me
Basic Rotational Flow andrewgould OpenFOAM Running, Solving & CFD 5 February 5, 2009 09:07
Rotational flow turbulence model ntrask OpenFOAM Running, Solving & CFD 3 February 3, 2009 10:59
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
Wall jet -tank with rotational flow in 3D Rodrigo FLUENT 2 June 10, 2004 14:05
Rotational effects for flow in disc cavities Karthik FLUENT 1 December 28, 2003 11:05
