Can not find temp.exe file
Old   June 27, 2006, 11:24
Default Can not find temp.exe file
Danko Davidovic
Hi I have a problem running the private version ofthe ground file with incorporated new turbulence model. Whenever I try to build the earth.exe the following message shows:
"temp.exe : fatal error LNK1120: 1 unresolved externals"
I loooked at bltear file following the reccomendation from one ofthe previous posts but I cannot resolve this problem. Can anybody help me with this?
Thank you
Old   June 28, 2006, 11:37
Default Re: Can not find temp.exe file
Mike
Unresolved external may refer to the fact that your ground file is calling a subroutine that is not present in the files that comprise your executable. Presumably, you can build earexe.exe successfully, if you use the default ground.for rather than your own ground.for.
Old   April 7, 2007, 09:58
satya
hi i hava run my system display dialog box that has problem occured in temp.exe file that's way your shut down your system. how i can recovery of that problem thank you
Cannot find file points derath OpenFOAM Running, Solving & CFD 1 May 4, 2007 12:04
how to find cycle average temp ammi FLUENT 0 January 22, 2007 03:01
I can not find the pstt file Z.H. Huang Siemens 5 December 6, 2005 09:24
I can not find %24HOMEbashrc file ztdep OpenFOAM Installation 6 August 18, 2005 03:38
HELP: Wall variable temp is not on the data file? Jiaying X Siemens 4 September 19, 2002 13:30
