March 5, 2014, 16:55 |
strange problem with structured mesh
Fangping
Rep Power: 12 |
I am a novice in pointwise. I just want to try a structured mesh for a 10*10 rectangle. First I just set the dimension as 81 for each connector and made the structure domain, see figure.1 below. However when I increased the dimension to a higher number such as 91, it didn't work, why? see figure.2.
It is very strange and frustrated. Any help is appreciated. 1.jpg 2.jpg |
March 5, 2014, 23:41 |
aerosapien
I suggest you to split the connector to half on all four sides and mesh for the four partitions.
March 6, 2014, 08:45 |
Chris Sideroff
Rep Power: 22 |
That is strange. It should not be necessary to split the connectors for such a trivial grid.
I created such a domain but didn't see this problem. Can you attach the grid for me to look at? While you can't upload .pw files, if you change the extension to .zip, you can attach it. |
March 6, 2014, 08:59 |
#4 | |
Fangping
Rep Power: 12 |
Attachment 29159 |
March 6, 2014, 10:55 |
Chris Sideroff
Rep Power: 22 |
The forum didn't link the attachment. Send me a PM and you can arrange to email it to me.
March 6, 2014, 14:23 |
Chris Sideroff
Rep Power: 22 |
Fangping
I loaded your .pw file into Pointwise and it looks OK (see image). Which version of Pointwise are you using? |
March 6, 2014, 14:28 |
Fangping
Rep Power: 12 |
March 6, 2014, 14:49 |
Chris Sideroff
Rep Power: 22 |
That's the version I tested it with (see previous image).
Are you still experiencing this problem? My only suggestion at this point is to select the domain and reinitialize it (button with little blue square with yellow star on the corner). |
March 6, 2014, 14:51 |
Fangping
Rep Power: 12 |
Similarly for a very simple extrusion problem. If I set the dimension number less than 90 and extrudes it for 10 steps, it works (figure.1). However once I increases the dimension number over 90, it doesn't work neither (figure.2).
1.jpg 2.jpg |
March 7, 2014, 08:12 |
Chris Sideroff
Rep Power: 22 |
That's very weird behavior. Do you see the same behavior if you use more than 91 points?
March 7, 2014, 08:55 |
#11 |
Fangping
Rep Power: 12 |
March 7, 2014, 09:39 |
#12 |
Chris Sideroff
Rep Power: 22 |
Can you report to me the model and tolerance values from File>Properties.
If it's not that, I'm leaning towards this being some obscure platform related bug. Which OS are you running? 32 or 64bit? |
March 7, 2014, 09:53 |
#13 | |
Fangping
Rep Power: 12 |
node: 0.0001 connector: 0.0001 grid point: 1.0e-7 my OS is 64-bit. Thanks! |
March 7, 2014, 09:57 |
#14 |
Chris Sideroff
Rep Power: 22 |
I did have one other thought. Can you change the display precision to double (Edit>Preferences, Graphics) and see if you get the same result. I might be a rendering issue.
If that's not it, I'm out of ideas :-/ |
March 7, 2014, 10:56 |
#15 |
Fangping
Rep Power: 12 |
Oh, it works, thank you so much, Chris! you helped me a lot.
March 7, 2014, 11:41 |
#16 |
Chris Sideroff
Rep Power: 22 |
Phew. Now that I know I am also able to replicate the issue. I'm surprised it was that sensitive.
Perhaps Pointwise can educate us on why that it does this. Strange when the range of floating point values only vary a couple of orders of magnitude. Perhaps you should submit a bug report and have them look at it. Last edited by cnsidero; March 7, 2014 at 13:27. |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 10:06 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
