November 28, 2010, 11:38 |
Meshing a Wheel in Pointwise/Fluent problem
Luke
Hi All,
I am attempting to mesh an external flow around an aircraft wheel (closed rim) in Pointwise to run using (at first) the k-e RKE model with Enhanced Wall Function. My mesh is built up in sections, first is the boundary layer. Using Y+ of 1 (0.0057mm) and expansion ratio of 1.2, for a wheel D of 1.4m, and reynolds number of 6.71x10^6, 70m/s. The quarter-wheel profile is meshed in 2d then rotated/mirrored around to cover the whole wheel. This is then built up into the far field cuboid mesh, 5.6m x 5.6m x 4.2m (infront) x 10m (behind), 3.6 million cells in total. (see attachments). Pointwise Wall Spacing examination corresponds to equivalent ~ 0.6>y+>1.6 around the whole wheel. Now, when I run it in Fluent, I get Continuity divergence after only about 50 iterations, and when I do a Turblence>YPlus contour in fluent I often see huge Y+ values (10^3), although this seems to vary depending on how long i run it, so I don't know whether due to the divergence this examination is irrelevant. So in summary, according to Pointwise, my y+ is pretty consistent, but I get continuity convergence quickly in fluent. I have re-meshed loads of times with same divergence. So not sure whether it's a Pointwise or Fluent problem. Any help would be much appreciated. |
November 28, 2010, 16:43 |
Chris Sideroff
Rep Power: 22 |
Luke,
What are the dimensions of the wheel? I ask because you have to make sure it's scaled properly in Fluent, as it works in meters. For example, if you created a wheel with a diameter of 1000 in Pointwise, representing the units mm, you will have to scale it in Fluent by a factor of 0.001. Since you reported y+ values 3 orders of magnitude higher than you were expecting, my guess is that your Reynolds number is 1000 too large, hence the incorrect scaling. Let me know if that works. -Chris |
November 28, 2010, 18:27 |
Luke
Genius! It worked!
Thanks Chris, this had been bugging me for weeks. It was indeed the scaling so Fluent thought my mesh was 10km long! Now I can move on to the proper stuff Many thanks again, I should have posted this ages ago. Yet another reason why CFD online/wiki is an indispensable resource! Luke |
January 22, 2011, 21:49 |
More scaling/units problem
I am using a k-omega SST model on a flow going through a duct. I should get my y+ between 1 and 5 I believe from what I've seen. I found out about a scaling issues in Fluent thanks to your previous posts. However I am still having difficulties obtaining the right y+ values from my mesh. When I try to adapt in Fluent it halves the y+ value but horribly increases the number of cells. My mesh y+ is about 60 so that I can't obtain the correct y+ value with a decent sized mesh in Fluent. I'm wondering if this is another scaling issue in Pointwise (importing from CATIA to Pointwise, or in Pointwise, do I have to set the units ? If I go to Properties the ratio of Grid/Database is about 600 ??). Or am I using the adapt function in Fluent wrong ? Any thoughts or suggestions greatly appreciated. Thank you !! |
January 26, 2011, 21:15 |
Tobino
Dear all,
I am meshing a model of ship. Have anybody known How to create structure mesh? please advise me ! |
March 14, 2016, 11:40 |
sclae
Rep Power: 10 |
hello
i create mesh in pointwise i import it in openfoam but i have a problem openfoam in default import mesh in meter but my mesh in mm. can anyone help me? thanks |
March 27, 2020, 00:47 |
Marium Mou
Rep Power: 6 |
have you succeeded? I am also trying to create structure mesh in pointwise.
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
Gambit meshing problem | nana | ANSYS Meshing & Geometry | 5 | August 31, 2009 05:58 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
Problem meshing very thin pipe | B. Hemmen | FLUENT | 2 | May 16, 2006 08:29 |
Meshing problem... | Gustaf | CFX | 2 | March 28, 2003 10:37 |
