Pressure Drop due to Friction
Old   April 29, 2012, 23:22
Default Pressure Drop due to Friction
sam
Sam0508 is on a distinguished road
Let me Explain the conditions of problem.
Pipe Ø4mm, Air velocity 50m/s, Turbulent flow, Dy viscosity 1.79E-5 N.S/m2, Density of Air 1.23kg/m3.Need of finding the Pressure Drop for 0.1m length.
The Calculation value is 1.076kPa,but in STAR CCM+ got value as 1.255kPa.In software i specified the B.C as Inlet-Velocity inlet 50m/s and outlet-massflow outlet -7.539E-9 kg/s and mentioned Roughness Height also for account of friction factor.
In physics continuum..Constant density/Segregated flow/Steady state/K-Epsilon Turbulence.
Can u tell me what i did wrong in software?
Thankyou,
Sam0508
Regards,
Sam
Sam0508 is offline   Reply With Quote
Old   April 30, 2012, 09:49
Ryan Coe
ryancoe is on a distinguished road
What is your 'calculation' value (is it from an empirical experiment)? If so, the CFD and empirical calculation should not necessarily be expected to match exactly.
Ryan
ryancoe is offline   Reply With Quote
Old   May 2, 2012, 01:30
Default Pressure drop due to friction
sam
Hi Ryan Coe,
It's not a experimental value, found by normal Dp(Pressure drop) Derived equation.i.e
Dp=(f*L*rho*V2)/(2*D) Dp units Pa
[f= friction factor(beased on Reynolds No and Relative Roughness), L=Pipe lenght 0.1m, rho=Density of Air, V= velocity of air 50m/s and D=Pipe diameter]
Why this values is not match with Theoritical data/Derived one.the difference(STAR CCM+ result Dp-Theoritical Dp result) is 170Pa,how we can accept? or What i did mistakes in this. Plz give ur feedback.Thankyou
Regards,
Sam
Pressure drop due to contraction and a subsequent expansion lionel89 Main CFD Forum 0 February 13, 2012 06:34
Pressure drop? Munni FLUENT 4 March 25, 2010 14:21
Pressure drop match praveen.jpk FLUENT 3 September 11, 2009 03:36
Pressure Drop in outlet Vent Abdul FLUENT 2 October 28, 2008 12:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
