Energy Balance problem
Old   May 9, 2012, 08:37
Smile Energy Balance problem
masud is on a distinguished road
Hi everyone
After ive finished running my simulation I did some checking, and found out that the Energy is not balanced even if the simulation converged.
Im simulating a asphalt solar collector and the model made of four parts. There are thre layers of asphalt(0.5mx0.25m) and a pipe where water flows inn it in the centre the asphalt layer in the middle.
The solar flux is coming inn at the top og the first layer of asfalt.
Any ideas?
Thanks for your answer
masud is offline   Reply With Quote
Old   May 23, 2012, 10:15
Ping
ping is on a distinguished road
sounds like you are only looking at residuals - you should always be monitoring some reports of key measurements like temperature and energy balance in a heat transfer case to ensure convergence. if your model has solids then set the solid energy under-relaxation to a very high number - the default is 0.99, but you should use 0.9999 or above and 1.0 works in many cases - this speeds convergence by many times.
ping is offline   Reply With Quote
energy balance, solar
Energy Balance in Thermoacoustic problems behrang2009 Main CFD Forum 2 July 28, 2010 11:33
Energy & Mass balance in RES file Lindel Phoenics 2 October 23, 2008 19:18
Energy Balance Harshad CFX 0 March 5, 2008 06:36
HELP needed: Energy balance in gaseous combustion James Willie FLUENT 11 August 10, 2005 04:58
Energy balance Eric FLUENT 1 February 17, 2004 19:33
