Outlet BC with Vof?
Old   May 26, 2012, 05:24
Question Outlet BC with Vof?
Januel is on a distinguished road
Question from a beginner:
I am running an analysis of a buoy with Vof and eulerian multiphase air/sea water. But what is the difference between the "Volum fraction air/sea water" and "Volume fraction Heavy/light fluid" boundary conditions? Manuals from CD-adapco suggest that "Heavy/light" fluid be used for velocity inlet and "air/sea water" for pressure outlet. When I use these settings it does not converge, but using "heavy/light" BC on outlet gives good convergence...
Running with 2DOF, z-translation and y-rotation (the latter rather large; <25 deg pitch-up).
Thanks!
Januel is offline   Reply With Quote
Old   May 28, 2012, 15:29
Ladnam is on a distinguished road
Heavy/light is the undisturbed volume fraction. Air/water is the resulting/disturbed volume fraction. So heavy/light should be used for BC.
Ladnam is offline   Reply With Quote
Old   May 28, 2012, 15:48
Thanks alot! Been wondering about that one and was unable to find an answer...
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 16:50
Downstream Pressure outlet BC - FLUENT VOF amwitt FLUENT 2 May 14, 2012 11:46
VOF outlet BC zhi FLUENT 2 April 9, 2008 07:29
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 08:07
VOF for flow problems with inlet and outlet Jannifer FLUENT 11 April 6, 2006 14:56
