rasidual in each cell, location of the cells with maximum residuals
Like Tree6Likes
  • 1 Post By Alex C.
  • 5 Post By azt
Old   November 28, 2013, 08:48
Default rasidual in each cell, location of the cells with maximum residuals
flux is on a distinguished road
is there any posibility to show me the positions of the cells, which have the highest residuals?
I couldn't find something in the manual...
THX!
flux is offline   Reply With Quote
Old   November 28, 2013, 09:23
Alex C. is on a distinguished road
One thing you can do, is create a user-defined field function which correspond to your model.
If you are using an incompressible, then
\nabla \vec{V} = 0
Therefore, if you create a field function which is div(V), it should show values near 0 in each cell.
The value I suggest you display will not be the same as residuals, but at least it can show you what part of the domain is less precise.
You can also create field-function for momentum equations, and eventually energy and turbulence, if you want to.
ebringley likes this.
Alex C. is offline   Reply With Quote
Old   November 28, 2013, 10:48
Default residuals
azt
allan thomson
azt is on a distinguished road
Hi
There is an easier way.
If you're using the segregated solver then:
solver -> segregated flow-> check the temporary storage retained box in the expert properties window
and run for 1 iteration.
The momentum residuals will be written out to field functions.
azt
azt is offline   Reply With Quote
Old   November 29, 2013, 04:53
ok thx...
now i've got field functions with the residuals... but how can i see the distribution over the cells... a scalar scene didn't show anything...
Old   November 29, 2013, 07:57
Default stuff
azt
allan thomson
Hi
you should be able to plot these as a scalar field.
you can createa report that gives you the max and min values. You can then create a threshold with say the top 10% and bottom 10% value and plot this.
That's how you do it.
azt
Old   November 29, 2013, 09:18
hm... i don't get any scalar-field plots.
i created a new scalar scene. Under displayers/Scalar 1, I added (under Parts) my fluid region. Under scalar field, i choose a Residual-field-function and nothing is happening.
It seems that this values are empty... because it does not show any Min/Max Values.
edit:
i forgot to say, that i am using a cluster... so on my desktop-pc, the values are available... is there any way to save the field functions in the .sim file?
there is another question: some residuals are negative... is there a way to get the values of residuals, which are displayed in the residual-plot?
Old   November 30, 2013, 04:17
Default stuf
azt
allan thomson
hi
you can't save temporary storage stuff to the sim file, which is a real pain. However you can write out the scaler field to a table file, and read it in later on.
azt
Old   December 2, 2013, 05:33
hi, thx! can you give me a short instruction, how to write out a scalar field to a table file?
Old   December 3, 2013, 06:26
azt
allan thomson
hi
tools -> tables -> right click -> new table -> xyz internal table
chose parts and scalars you want to export
then right click -> extract then right click export
Read this file in later and create a field function using the function InterpolatePositionTable
see help for syntax
azt
Old   December 10, 2013, 08:48
sorry for my late answer! i will try it, thx!
Old   August 24, 2016, 18:17
Walther is on a distinguished road
Sry for this post. After I read aztīs answer I thought this option for temporary storage retained is only available for segregated and posted my question. But you can use it for coupled or turbulence solvers, too. I wanted to delete my post, but couldnt find a way to do it.
Walther is offline   Reply With Quote
[snappyHexMesh] Snappy creates strange cells far away from boundary vainilreb OpenFOAM Meshing & Mesh Conversion 3 December 16, 2020 05:11
Solution Diverging with Trimmer Mesh rietuk STAR-CCM+ 8 February 27, 2013 04:50
[Other] cgnsToFoam problems with "QUAD_4" cells lentschi OpenFOAM Meshing & Mesh Conversion 1 March 9, 2011 04:49
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Ghost cell location for inclined cavity flow zonexo Main CFD Forum 13 September 9, 2005 02:00
