June 4, 2013, 21:44 |
rough wall
adam
Rep Power: 14 |
If I have a fluid/solid interface between a heat generating object and air, if I wanted to represent the object as having a roughness (for example, a transformer with bundles of windings), where would I apply this? Would I go under the fluid region and find the interface corresponding to the same solid surface and change the wall from smooth to rough? Or would I change the boundary and not the interface to rough? Or both? There is no smooth/rough option with solid region boundaries.
I'm looking at how the roughness affects the heat transfer from the object, but so far after changing the fluid interface to rough and rerunning the simulations everything looks the same. Maybe this is the correct result, or maybe I'm applying the roughness incorrectly I do not know. |
[blockMesh] StitchMesh on two patches | anita | OpenFOAM Meshing & Mesh Conversion | 31 | April 4, 2013 11:51 |
Is wall ajacent temperature equal to conservative temperature of the wall? | shenying0710 | CFX | 8 | January 4, 2013 04:03 |
strange solver behavior---Treatment of Rough Wall | Yi | CFX | 6 | April 14, 2010 18:31 |
Rough walls and SST (CFX11) | Sans | CFX | 2 | October 3, 2007 06:12 |
the law of the wall for rough surface | maximus | Main CFD Forum | 0 | January 31, 2004 08:45 |
