STAR-CCM+ 5.04.008 on a 32 bit machine
Old   August 23, 2010, 02:00
Default STAR-CCM+ 5.04.008 on a 32 bit machine
toby
tobe is on a distinguished road
I am currently trying to install STAR-CCM+ (32) 5.04.008 on my personell machine so I can create files to run on our solver and speed up the process of creating and solving files. But I can not do any work in dual core mode, but only in sigle license.
It looks like the mpi software is not being loaded at all when i install the software. Has anyone else had a similar problem?
tobe is offline   Reply With Quote
Old   August 23, 2010, 10:50
Pete Launie
plaunie is on a distinguished road
How many licenses do you have? 1 seat of Star CCM = 1 core.
If you have multiple licenses, when you open the sim you specify how many cores to run the sim on:
set run mode -> parallel
in the detail box choose how many compute processes to run.
plaunie is offline   Reply With Quote
Old   August 23, 2010, 20:48
toby
We have mutliple licenses and yes i select to run it on multi cores but the mpi is not loading properly, so it does not allow the load. the error is "Server process ended unexpectedly (return code 1) See the Users Guide for complete information.:"
Old   August 24, 2010, 02:20
jarry is on a distinguished road
Hello tobe,
i hade the same problem, but with 4.04.
When I installed 3.06 with the mpi it works. Try to install also 3.06 and run the simulation with 5.04.
jarry is offline   Reply With Quote
Old   August 24, 2010, 19:10
toby
It looks like from v4.06 you need to make sure you have service pack 3 installed on your machine. I am downloading it now and will let you know if it works
Old   August 24, 2010, 22:40
toby
Yes it worked, so Jarry that may have solved your problem as well
Old   July 25, 2012, 01:27
Belgique
Rom1 is on a distinguished road
I have a similar problem with windows 7 (64 bits) and the version 5.06.
any help ?
Rom1 is offline   Reply With Quote
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
error in star ccm maurizio Siemens 3 October 16, 2007 05:17
CFdesign software for 64 bit machine M_Marivani Autodesk Simulation CFD 0 April 20, 2006 09:50
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
