December 3, 2012, 16:54 |
Odd mesh in aerofoil
Eleanor V
Rep Power: 13 |
Hi all,
I have attempted to mesh a box around a naca aerofoil to simulate the flow field. However, when I try to refine the mesh it creates odd parts inside the aerofoil. Im pretty sure it isnt the CAD as i have it working on another simulation. The only problem that I thought it might be is because I said to use Prism layers but it hasnt put any on. I have attached a picture with the weird mesh, and any thoughts as to why that is happening or why the prism layers arent showing up would be really helpful, thanks! |
December 4, 2012, 20:59 |
KHB
Rep Power: 15 |
Try to reduce the surface cell size maybe?
You can try to do the surface mesh first (no need to perform the volume mesh) and then see how does the mesh looks like. You can also post the picture here. It might be that the surface mesh representation is not good so that it creates a bad volume mesh |
December 8, 2012, 17:49 |
Eleanor V
Rep Power: 13 |
Thank you for your reply, unfortunately changing the surface mesh first doesnt seem to help. The problem seems to happen as I refine the mesh. if i have a fairly coarse mesh, giving a crude outline of the aerofoil it is fine, and then as i refine it, it gives these weird shapes (shown in above picture). if I then make it coarse again, they go away-or at least get a lot better.
Any thoughts would be appreciated! Thank you |
December 9, 2012, 06:24 |
Rep Power: 13 |
maybe try and add contact prevention?
December 9, 2012, 11:31 |
Eleanor V
Rep Power: 13 |
Hi Shyam 88,
How would I do that please? Thank you |
December 9, 2012, 12:30 |
Rep Power: 13 |
regions > air > mesh values > contact prevention, right click new, one group contact prevention.
select boundaries, ie airfoil search floor - make it really small in comparison to your mesh size. |
December 13, 2012, 15:54 |
Eleanor V
Rep Power: 13 |
thanks thats great. Thanks for your help |
cad, meshed wrong, prism layer |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
