Benchmark Commannd Line
Old   January 27, 2013, 08:58
Default Benchmark Commannd Line
eRzBeNgEl is on a distinguished road
Hi guys,
I just want to benchmark our new hpc cluster and need information about the command line how to start starccm by console.
I used in earlier versions the following command:
starccm+ benchmark.sim -benchmark:" -nits 1000 -nps 1,2,3,4,5,6" -np 6
Somehow it does not work anymore. starccm starts the process always with kust one node and it says that the command extenstion "-benchmark" does not exist. But it worked with Star-CCM+ V6xxx
My current version is V7.06.009 and my OS is Debian Linux.
Thanks for help
eRzBeNgEl is offline   Reply With Quote
Old   February 13, 2013, 04:22
murash-v
murash-v is on a distinguished road
Hi. I have the same problem now. Did you solve it?
Originally Posted by eRzBeNgEl View Post
Hi guys,
Thanks for help
murash-v is offline   Reply With Quote
Old   February 17, 2013, 15:27
Hi
You need just to wait. The benchmark starts with one node, iterates e.g. 100xtimes and then it will benchmark with two nodes up to max level you have entered in "-nps". I think there is a command extension where you can say with which node the benchmark should start. The "-benchmark" option itself only worked on one machine. If i wanted to check two machines e.g. "-on cluster01:6, cluster02:6" the benchmark mode did not work. Therefore I just created a few reports (Total overall elapsed time, cpu time) and run a "normal" simulation. For results I piped the ouput window into a log file and made my checks.
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
