Cold Glass Surface And Air Behavior
Old   March 18, 2013, 09:51
Default Cold Glass Surface And Air Behavior
Maher Al Taweel
Maher_Al_Taweel is on a distinguished road
Hello!
I have a problem with a temperature and speed simulation of air. I want to simulate the behavior of the air in a large room (21 x 18 x 6). I have fix floor and wall temperatures. And I have a large glass surface with a low temperature around 270 K. Therefore, I would consider lifting forces with respect to gravity and density differences. The physical characteristics that I have chosen are:
Three dimensinal
gradients
steady
gas (air)
Coupled flow
turbulent
Reynolds-averaged Navier-Stokes
K-epsilon
Realizable k-epsilon two layer
Two-layer all y wall treatment
Gravity
After some itterationer Redisualen becomes very large and the simulation stops. How do I resolve this problem?
Maher_Al_Taweel is offline   Reply With Quote
Old   March 19, 2013, 06:39
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
You can run the simulation first by changing the solvers to be first order. If it did not diverge, let it to be converged completely and then change it one by one to second order.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   March 20, 2013, 07:39
Maher Al Taweel
Thanks, I changed the convergence accelerators from none to continuity convergence accelerator, and now it works.
Best regards
Maher A.
Radiation through: glass – air cavity – glass Yingchun CFX 7 February 27, 2012 16:46
how to get total mass of air through a surface yubaibai88 FLUENT 0 June 2, 2010 08:14
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
surface to s. radiation in air above transp. fluid dace CFX 1 March 3, 2009 07:35
Free surface flow with air entrainment Ken CFX 4 October 17, 2005 23:01
