Natural Convection: Energy residual does not converge
Old   April 5, 2013, 15:37
Default Natural Convection: Energy residual does not converge
Etienne Mullin
Nukengine is on a distinguished road
Hey all,
I am relatively new to CFD.
I am simulating natural circulation in a small box (~6inx6inx16in tall box) with 2 heater rods placed inside along the height and gravity. The rods have 'heat source' thermal conditions; one rods is at 400W, the other at 250W. The top wall of the box has a heat source condition as well of -650W. The fluid in question is water (using a polynomial in T density because the IAFW water thing generally gave me errors with T and P out of bounds).
I have run the simulation with various physics continua and solver settings and finally have a solution that appears realistic. I have also refined mesh and I don't think that is an issue. The problem is that under all of the continua and solver settings I have tried (whether turbulent/laminar or steady/unsteady) my energy residual flattens out at just over 10. The XYZ momentum residuals are 10^-5, continuity 10^-3. Under turbulent models (K-Omega) TKE is about 10 and SDR is about 0.01.
My question may simply be answered by telling me that a high energy residual in a natural convection simulation in STAR CCM is normal and acceptable. Otherwise I would appreciate some opinions; I can list more simulation parameters.
Thanks!
Nukengine is offline   Reply With Quote
Old   April 10, 2013, 08:53
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
I do not think that it is normal. I think there is a problem. Are you sure that the solution is converged? check if the solution is converged
Good luck
Siamak
siara817 is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
