Trimmer vs. Polyhedral - problem in an optimizer
Old   September 17, 2013, 03:35
Default Trimmer vs. Polyhedral - problem in an optimizer
renee is on a distinguished road
Hello everybody,
my current problem is quite challenging since days. I am using an optimizer which imports a CAD file. After setup the inlet and outlet, it generates an optimized shape by avoiding deadzones in the velocity field. That means, it cuts off areas in my geometry, which are below a specific velocity. I tried to change the Mesh-Properties, which original contained a TRIMMER, to a POLYHEDRAL MESHER. After that, the error notice said that CAD projection mode has to be enabled. So I enabled the CAD projection mode. Since that, the optimizer doesn't work properly anymore.
Does anyone has an idea?
Thanks!
renee is offline   Reply With Quote
Old   September 19, 2013, 06:28
Oliver Lauer
olauer is on a distinguished road
Which optimizer are you talking about? ToscaFluid?
Did you ask their support or is it a hand written opimizer?
olauer is offline   Reply With Quote
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
