free surface flow inside channel that gets narrower
Old   June 3, 2013, 17:34
Default free surface flow inside channel that gets narrower
JohnAB is on a distinguished road
My system is pretty simple:
a classical channel, one inlet one outlet, everything else are walls. The inlet is larger that the outlet after a small reduction in width (type nozzle).
My goal seems pretty simple too:
visualize the free surface, i.e. the waves and elevation of water caused by that nozzle, if any.
What I did:
I have carefully read and tried to reproduce the boat tutorial. I have VOF waves that are very small but help me (I guess) generate the mean current in the channel without having to write a field function myself for the mean water depth. (I tried that too, it did not work).
What bothers me a lot with VOF waves is the parameter called "point on water level", which seems to be responsible for the water depth (I can put anything under "water depth", it is the "point on water level" that will define the water depth...) and I think this is the source of my problem but I do not see how to solve it.
When I run the simulation, the initialization goes well, but then, it looks like the water and the small generated waves from the inlet just perfectly slide on the walls (even if I have the non-slip condition) without being affected (no water elevation, no wave, nothing). The nozzle does not do anything and even more interesting, even if I change the Outlet to a Wall, the channel does not fill up, the water level do not change at all...
Could anyone please help me solve this and get the waves (generated from the nozzle) and the water elevation I am supposed to get ?
I have attached my case, if anybody wants to try to run it. It is ready to be surface&volume meshed, then hit run.
PS: I have a fine mesh and 0.01s time step, so this is not the issue I think.
The plot is a 0.5 volume of fluid isosurface.
the water speed is 2.5m/s along x.
the total length of the channel is 2m along x.
the water depth is 30cm.
the nozzle thickness is about 20cm.
JohnAB is offline   Reply With Quote
Old   June 12, 2013, 12:31
Hello again,
I still haven't figured out a way to get the correct free surface. Did anybody got the chance to take a look at it ?
I have also tried without the waves, i.e. only inlet (velocity inlet with a field function to define the water level) and outlet (pressure outlet), and in that case it looks like something happens, but it is still not good since I am losing water over time (empty channel after about 2 seconds of simulation) through the outlet, even with a refined mesh (base side would be like 0.01 for a 30cm*200cm channel) and small time step (0.05s).
Again, I have looked at the tutorials, and I am stuck here...
Old   June 24, 2013, 06:49
Kons
fuzel is on a distinguished road
Hi John,
have you figured out what caused your problem? If not I am happy to have a look at it later this week...
Cheers
Kons
fuzel is offline   Reply With Quote
Old   June 24, 2013, 14:43
Hello fuzel,
No I haven't figured it out yet.
I made this work without the waves, just with velocity inlet and it looks good, my issue was that I had to use a trimmer mesh. But regarding the case with the waves, it still does not work at all, the wave do not "see" the geometry change.
I would be very glad if you could made it work!
Thanks!
Old   June 24, 2013, 15:48
Kons
Hey John,
I ll have a go at it over the weekend. Regarding your point with the water depth:
The waterDEPTh is used by starccm for the respective formulation of wavetheory where as the actual water level is set by giving an initial point of the free surface. This gives you the advantage that you could basically model a deep water wave without having to have a really deep domain. So its not a bug it's a feature
Cheers
Kons
Free surface flow settubg boundary conditions and plotting velocity profiles prashanthreddyh FLUENT 2 October 21, 2015 09:58
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
CFX gravity driven free surface flow tutorial mechovator CFX 37 July 27, 2009 10:28
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
