problem writing field function
Old   July 17, 2013, 13:01
Default problem writing field function
shoumo
amarjogot is on a distinguished road
Hello everyone, I am having some problem using star CCM+ for my model. I was trying to use a specific function for my velocity inlet. As my model is a cylinder. It has two velocity component. One with the radial and another one with the tangential. I used a code while using it in the fluent (attached file). I am also not sure how to compile user defined function in star ccm+. Thanks in advance for the assistance.
Zoheb
File Type: c zohebvelnew.c (935 Bytes, 63 views)
amarjogot is offline   Reply With Quote
Old   January 5, 2014, 21:16
phanh
phanh is on a distinguished road
Zoheb
Hi Zobeb,
Did you solve your problem? I have the similar problem but I have not yet know how to do it. Can you give me some advises?
Thank you so much.
phanh is offline   Reply With Quote
Old   January 6, 2014, 20:23
DSK
dsk2 is on a distinguished road
Phanh,
You may have resurrected an old thread.
In order to specify the inlet velocity as a variable, you can use a field function in "Tools->Field Functions"
Create 3 field functions for velocity, say, Velx, Vely and Velz.
In order to specify variable components for velocity, change the velocity from constant to composite. Then you will have to an option to specify x, y and z velocity components. Change the velocity component from constant to field function for x, y and z velocity component and assign the corresponding field functions- Velx, Vely and Velz.
Note: the function $$Position("Cylindrical 1") returns a cartesian vector of the position coordinates in local coordinate system Cylindrical 1; the subscript operator [] is appended to access a single component of the position vector (with an index of [0], [1], or [2]).
dsk2 is offline   Reply With Quote
Old   January 6, 2014, 22:03
phanh
Originally Posted by dsk2 View Post
Phanh,
Hi DSK,
Thank you for your recommendation. Using user field function, I have succeeded for my requirement. But your suggestion is a good way that I should try it. Could you tell me how to do it with user code in STAR CCM+? For some reason, I prefer definition of velocity profile by user code (by C language) rather than user field function.
Best regards.
star ccm+, user defined function, velocity
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
Problem with Field Function gmoehl STAR-CCM+ 2 August 18, 2012 04:17
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
