Why the drag coefficient has negative value?
Old   January 27, 2011, 02:55
Default Why the drag coefficient has negative value?
Ji-nam, Kim
suiede is on a distinguished road
Hi, all. I'm trying 2D simulation of NACA0012 in re=2.88e6. I'm using k-w sst gamma re theta in steady, stationary condition.
I had have a good result in using k-e solver, but in this case, it shows me negative value of drag coefficient.
I have no idea about it, please help me to solve this problem.
Thank you.
suiede is offline   Reply With Quote
Old   January 28, 2011, 20:19
Naimish Harpal (MS Aerospace Engr)
naimishharpal is on a distinguished road
Make sure that you are defining the Drag force in Positive-X axis (downstream) direction.
naimishharpal is offline   Reply With Quote
Old   December 4, 2013, 00:39
Basavaraj H M
BASU HM is on a distinguished road
hello every one,i'm also using same turbulence model k-omega sst,im trying to simulate 3D ship in viscous flow under open channel wave BC,multiphase,inlet velocity,outlet pressure,but im getting negative Drag, Lift and moment coefficient.net mass flow rate is not zero.......suggestion please
BASU HM is offline   Reply With Quote
Old   December 4, 2013, 06:36
Gajendra Gulgulia
ggulgulia is on a distinguished road
Hey Suide
The drag value has nothing to do with the turbulence model as far as you have selected the right turbulence model ( I know this sounds a little ambiguous)
In star CCM+ there are two directions. Make sure the direction of the report is along the downstream direction of flow.
SST K-w models should be used for low RE flow to capture the near wall phenomena. If your boundary layer is not that important, then I suggest you go with realizable K-e turbulence model.
ggulgulia is offline   Reply With Quote
Negative drag coefficient... fletc900 OpenFOAM Running, Solving & CFD 14 September 5, 2022 10:33
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
why my Drag coefficient value is negative value Liu CFX 7 June 28, 2008 07:09
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
