March 15, 2014, 21:55 |
Importing 3D Curve problem (Updated)
Rep Power: 12 |
[UPDATE] I was able to figure out the problem of the continuous line and get a correct arrangement of 3D curves (attached file). However, when trying to loft the curves it comes up with an error. Hoping someone can help!
I was hoping somebody would be able to help. When i import the attached file (.csv format) the curves aren't treated as separate and instead joined up by one long spiral. The help file says that leaving a blank line between each 3D curve will do it but it hasn't Here is what it looks like Thanks! Last edited by lint; March 16, 2014 at 20:54. |
April 5, 2014, 08:09 |
#2 | |
Philhellene Ithaca
Rep Power: 12 |
If you scale your curves by , the lofting works (tried with the attached zip file in version 8.06). Once you've created the geometric part you can then scale back to original size. |
April 5, 2014, 22:40 |
Rep Power: 12 |
Thanks yannaos, I did guess that was the problem in the end and scaled the model down before importing it and then just scaled the mesh up.
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Importing surface/profile for data writing in Fluent | fadiga | FLUENT | 4 | July 12, 2014 01:23 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
problem importing mesh into gambit | tsm554 | FLUENT | 7 | December 3, 2010 22:15 |
Problem in Track Data | selen | Siemens | 2 | August 7, 2003 13:06 |
