March 22, 2014, 02:52 |
mass flow of inlet and outlet is not equal
Rep Power: 12 |
a simulation, the force result looks convergence, but de mass flow of inlet is not the same as the one of outlet. why? how should i deal with the issue?
March 22, 2014, 19:09 |
Rep Power: 24 |
Is the mass just not converged yet?
March 25, 2014, 09:29 |
Ping
Rep Power: 20 |
looks like you are doing a marine vof case on the wigly hull. you need to be careful when measuring mass flows of water and air in and out of such cases when motion is involved etc. i'd be create a monitor and plot of this to look at the history and when such models are well setup the mass flows do converge but also cycle around zero due to motion and waves. most marine users never do such a report and instead look and convergence of forces, moments and motions.
mass flow |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
Species mass flow inlet | lorenz | FLUENT | 3 | March 15, 2012 07:26 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 10:09 |
