March 25, 2014, 17:09 |
Star Time Integration
Doug Hunsaker
Rep Power: 17 |
I'm running a transient analysis of an airfoil going through a sinusoidal motion. I specify the velocity as a function of time through a user-defined field function and link that to the oveset mesh. Star then integrates the velocity to obtain the new position for each step of the simulation.
It appears that Star is using a rectangle rule for time integration, which is a very low-order method. Is there a way to specify a higher-order method for that time integration? Like 4th-order Runge-Kutta? With the current integration scheme, my position during the sinusoidal motion is off by 2% with 128 time steps per cycle. Even trapezoidal integration would reduce that significantly. Any input would be appreciated. |
March 25, 2014, 20:05 |
Doug Hunsaker
Rep Power: 17 |
I just found an option that allows me to specify the overset grid position rather than the overset grid velocity. This option allows me to accurately define the position. However, I would like to check the velocity of the overset grid as a function of time. It should simply be the derivative of the position, but I would like to check it for accuracy. Does anyone know how to output the grid velocity (not the velocity of the fluid passing through the grid)? I've searched the documentation but haven't found any information on it.
Thanks in advance. |
Display Modes | |
time step directories naming issue | Andrea_85 | OpenFOAM | 3 | April 3, 2014 09:38 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 08:56 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
