Conveyor Tutorial Flow Rate
Old   September 19, 2014, 10:43
Default Conveyor Tutorial Flow Rate
Damon Peak
Damon in STL is on a distinguished road
Just starting to work with CCM+ and working with the conveyor tutorial.
For the Particle Flow Rate Constant.....what do each of the variables "$Time < 0.5 ? 100 : 0" mean?
Damon
Damon in STL is offline   Reply With Quote
Old   September 24, 2014, 09:57
Damon Peak
So, no one knows what the base user functions mean....or where to find their meaning? Can someone point me in the right direction to find this info?
Damon
Old   October 1, 2014, 11:16
Joshua Brickel
JoshuaB is on a distinguished road
There is only one variable that is $Time which is a scalar in Star-CCM+.
The other tidbits are Java formats. Basically it is an if-then-else statement.
If $Time<0.5
then result is 100
else result is 0
JoshuaB is offline   Reply With Quote
Old   October 1, 2014, 19:01
Damon Peak
If $Time<0.5
then result is 100
else result is 0
LOL....the only guy who answers the question sits two offices down......
Thanks Joshua
Damon in STL
Old   June 9, 2015, 10:15
Eli DeGroff
Eli Roman is on a distinguished road
So is that line of code supposed to work as is when typed in as a value?
I am using STAR CCM+ V10.02 and it doesn't seem to accept it.
Thanks,
Eli Roman is offline   Reply With Quote
Old   June 9, 2015, 11:34
Joshua Brickel
It worked with a version of 9.06.009.
When you say Star-CCM+ is not accepting it, do you mean it gives an error message? Or does it default back to some constant?
Thanks,
Old   June 9, 2015, 11:53
Eli DeGroff
It would give me an error message and say something about trying to put in an invalid field function.
I messed with it for awhile and got it to work, I think taking the spaces out of the code fixed it. I had spaces in it as it appears in the tutorial and that seemed to be causing errors.
Thank you for your reponse.
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 13:14
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 17:24
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 17:57
Mass Flow Rate Error jallison FLUENT 1 May 16, 2011 16:22
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
